Results 1 to 9 of 9
Thread: [News] AMD's Upcoming RX 500 Rebrands to use LPP Process - Higher Clocks, Lower Power
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    https://www.techpowerup.com/231692/a...ks-lower-power
    AMD's upcoming RX 500 series of graphics cards is not going to set the world on fire with its feature-set. Essentially rebrands of AMD's mainstream Polaris GPUs used in current-generation RX 400 series, these have recently seen a slight delay on its time to market - now set at April 18th.
    While architecture-level adjustments to this new series of cards so as to improve performance seem to be off the table, AMD is apparently looking to take advantage of manufacturing maturing and process improvements. The original Polaris 11 and Polaris 10 chips were manufactured using the Low Power Early (LPE) process, which looks to balance availability, yields, and time-to-market with performance and power. New reports peg the new dies to carry the Polaris 21 and Polaris 20 monikers, and will feature higher clocks on account of the new Low Power Performance (LPP) process.
    Oct 2012
    Well , if they are actually using another process type, that means a somewhat revised die, its pretty OK to call them 5xx series, its not a typical rebrand when you get exactly same stuff with another name.Hope they clock to ~1500.If they would use GDDR5X it could actually mean a healthy boost.
    Intel 5960X@4.2Ghz[Prime stable]@4.5 [XTU stable] 1.24v NB@3.6ghz Asrock X99 Extreme 3 4x8GB Corsair Vengeance@3200 16-17-17
    Sapphire nitro+ VEGA 56 Samsung SSD 850 256GB Crucial MX100 512GB HDD:WD10TB WD:8TB Seagate8TB
    Aug 2008
    Quote Originally Posted by vario View Post
    It's not even a die shrink or recised steppig. It's still the same chip. I'd be surprised if we see any gain over 10%.
    Oct 2012
    Quote Originally Posted by StAndrew View Post
    Its not a die shrink, but it is a different process, and thats why it cant be exactly the same , so it has to be revised.but im also betting at around 10%.
    If it would be THE SAME tho, it would be 0%
    Aug 2008
    There is a difference between revising the manufacturing process and changing the arcitecture design. That would be like Intel launching a new processor every stepping.
    It's stills a rebranding.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    x2 Samsung 850Evo 500GB
    x 1 500 Samsung 860Evo NVME
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Full Cover GPU blocks
    360 x1, 280 x1, 240 x1, 120 x1 Radiators
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    you mean like devils canyon? i can see doing that but ya this making it a 500 is BS unless it has the change like a 4870 to 4890.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Feb 2009
    Hawaii
    It's probably being named 500 to launch along with vega so that the line looks more complete.
    Xeon E3-1245 @ Stock | Gigabyte H87N-Wifi | 16GB Crucial Ballistix LP @ 1600Mhz | R7 260x | Much and varied storage
    Aug 2008
    Quote Originally Posted by Darakian View Post
    Basically. Similar to what NVIDIA did with the 9800 GTX when theu launches the GTX 280. IIRC, it was branded as a GTS 250.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Jul 2007
    SF bay area, CA
    wast that also the same as the 8800gt and the 180gtx oem.
