Post up pics of your Ryzen Rigs. Kinda like the sound of that.
I just saw a bad ass one on water cooling at microcenter Cambridge, shoulda snapped a pic.
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
Good one with the thread title .Happens rarely but i really laughed out loud.
Intel 5960X@4.2Ghz[Prime stable]@4.5 [XTU stable] 1.24v NB@3.6ghz Asrock X99 Extreme 3 4x8GB Corsair Vengeance@3200 16-17-17
Sapphire nitro+ VEGA 56 Samsung SSD 850 256GB Crucial MX100 512GB HDD:WD10TB WD:8TB Seagate8TB
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
Mine is disassembled at present...
Will surely do so soon
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
Hardware shots!!
heatware chew*
heatware chew*
ROG Power PCs - Intel and AMD
I've been waiting for this since the first Ryzen info slipped out however many years ago.
Posting in here with everyone while tweaking / benching our Phenom 2's was some of the most fun I've ever had in an online community and one of the last times this place was really really poppin'. chew*, daveburt, flanker, tonyocz, charged & beepbeep (and many I'm missing)
Bummed my hardware hasn't come in, originally pre-ordered a Crosshair VI & 1800X from Amazon but you're probably all aware of that fiasco. Ended up dropping to a 1700 for now until we get a few more steppings and some more OC headroom at the top-end a they are all seem to topping out give or take +/- 100-200mhz.
I've got my HK IV Pro, 3x 360MM Rad's waiting for it and I think I'm gonna go with either the Asrock Taichi or Giga Gaming K7 instead of the CHVI (wait for Formula/Extreme variant) and some gskill samsung b-die.
Will start tweaking / posting results once everything is in, and motherboards finally freaking come back in stock.
May also take my first foray into LN2 instead of the usual water in the coming months!
Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
--- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
--- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
Ya, I had a blast with Phenom, and Phenom II in this community. I just checked HW bot, and I still have 0.8 hardware points dating back to 2009
In fact those were my last desktop PC's, and have since moved to gaming laptops. Not as fun, but take up less room.
heatware chew*
Here is my 24/7 built:
Asus Crosshair Vl Hero / R7 1700x @ 4.0Ghz on Swiftech Apogee XL H2O / G.Skill 16GB DDR4-3200 Cas14 / eVGA GTX 1070 SC on EK H2O / X-Fi Titanium Sound Card / 1TB crucial MX-300 SSD OS + 3TB Toshiba HDD Storage / eVGA SpernovaG2 1300w PSU / Custom H2O Loop - Swiftech Apogee XL for CPU , EK-FC1070 GTX Nickel Plexi Top for GPU , 2x 140mm Swiftech Radiator - MCR140 ( Top and Rear ) Push + 1x 280mm Swiftech Radiator - MCR240 ( Front ) Push Pull Configuration , Primochill Advanced LRT Cristal Clear Tubing 3/8 x 5/8 , Swiftech 3/8" x 5/8" Lok-Seal Compression Fittings - Black , Maelstrom 5 1/4" Dual Bay Reservoir , 6x Corsair Air Series SP140 LED Red High Static Pressure 140mm Fans / All inside a Corsair Graphite Series 760T Black full-tower.
Nice guys keep em coming.
heatware chew*
My Ryzen build and first stab at watercooling
Specs:
Ryzen 1700x
ASRock x370 Taichi
32gb (4x8) GSkill TridentZ 3300 16-16-16-36
EVGA GTX 1080 Hydro Copper
2x 1tb Intel 600p m2 drives
Seasonic SSR-850TD
Cpu is at 3.9ghz with ~1.32v. 4ghz is rock stable at 1.4v but I'm going with 3.9 for 24/7, less power and ~7c better load temps. 4.1 boots into windows at 1.45v but cinebench crashes instantly, didn't try more voltage.
Ram is running fine at 2666 14-14-14-34, 2933 actually boots and runs benchmarks but seems to need CL18 to do so, anything lower is no post/reboot loop... will probably tinker some more or run with 2 sticks at some point to see if it can go higher, I'm open to any suggestions but so far it seems difficult to get 4 dimms running very fast.
ASRock Z77 Extreme4 || i7 3770k @ 4.4ghz || MSI 4gb GTX 770 (stock) || 4x8gb Ballistix Sport DDR3 1600 (stock)
