GeIL launched its flagship EVO-X line of high-performance DDR4 memory modules featuring RGB LED lighting, which it unveiled at the 2017 International CES, earlier this year. The modules feature a diffused RGB LED lighting element that takes input from most RGB LED standards over 4-pin headers, such as ASUS Aura Sync, ASRock Aura RGB, MSI Mystic Light Sync, and GIGABYTE RGB Fusion. The modules feature two inputs, one on either side. One plugs into a 4-pin RGB LED header, and the other draws additional power from a 9V/12V power source, such as a fan header.
Internally, the LED lighting element is placed on a separate PCB from the actual DRAM module, so there's no scope for electrical interference that can destabilize the memory. The modules come in 4 GB, 8 GB, and 16 GB densities, and in a wide range of speeds and timing combinations, including DDR4-2133, DDR4-2400, DDR4-3000, DDR4-3466, DDR4-4000, and DDR4-4133. The modules further come in single-module and dual-channel kits; and with two heatspreader color options - glossy white and matte black. The company didn't reveal pricing.
