Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: Zen AMD X370 Will W7pro work?
  1. #26
    Xtreme Member eagle101's Avatar
    May 2003
    SoCal USA
    Quote Originally Posted by zanzabar View Post
    that is always how OEM has worked. what you want is OEI if you wanted retail with no support, or just to ignore the TOS bit on that since if you keep the same user it is still the same computer even if you change all the parts.
    I will get back to you on this zanzabar.....thank you
    Thanks Eagle101
    CrossHairV-Z 9590 cpu-OC
    SSD Ocz RevoDrive3 X2 Raid0 PciE
    -51c Cpu SS Phase.Change Cooling
    Msi 290X Lightning oc
    1600 Watts P2 Evga Platinum
    G.SKILL Trident X Cas7 1600Mhz
    Dell U2410 24" IPS
    5.1 Sound Pro-Klipsch
  2. #27
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    Quote Originally Posted by chew* View Post
    Xp is ehh. Core limited so pointless. Even win7 32 is limited in gaming. I recall titanfall needed a rig with 16gb installed to run smooth. Even 8 gig would get chewed right up and run poorly. No clue on titanfall 2. Hardcore gamers have 2 choices win 7 64 or win 10. I would not even consider win 8 as a gaming platform.
    I will shift to win 10 eventually but only when i choose to. I like doing things by choice not by force.
    XP for Superpi 32M AMD WR :P
    ROG Power PCs - Intel and AMD
