The Corsair K70 RGB LUX Retail $159.99
http://www.corsair.com/en-us/k70-lux...erry-mx-red-na
The Asus Claymore Retail $159.99
http://www.asus.com/ROG-Republic-Of-.../ROG-Claymore/
Both are full RGB with software.
Both are Cherry MX.
Both have pre set patterns to bring the keyboard to life.
Both have high quality cable, Asus is slightly nicer and removable (Micro USB).
Asus Claymore is slightly brighter, possible profile differences.
Corsair LUX will often have software failure and not resume color profile after sleep mode.
Asus Claymore has detachable number pad with larger volume knob.
Corsair has on/off buttons for more RGB control, Asus uses function + key to control lighting from the keyboard.
Both keyboards feel great, exactly the same.
Asus Claymore is slightly heavier.
Asus Claymore is styled nicer and has a geometric patterning that is tactile.
They both have a nice default color scheme if you do not use the software.
The Corsair worked like a champ right out of the box, no issues at all.
The Asus Claymore had issues from first use, depressing any key would produce too many of that character in the OS or in BIOS, connected to any machine. But after software and firmware updates it resolved that issue, cost me 15 minutes of quality brain inactivity. I had to click the wrench in the "Armory" software to get the updates twice.
After a few days of testing one at home and one at the office I have come to the conclusion that the Corsair K70 is the better keyboard if you were to buy today. Asus is having some issues with key depression not registering the stroke or doubling the stroke. My keyboard has this issue and while playing games so I swapped home with work so that I had the Corsair for gaming.
Winner: Corsair K70 RGB LUX
I will need to give Asus more time for another update in hopes it fixes my key depression issue.
