Class #6 (SocketA Watercooled)
still running cpu under 2.3GHz
Vid card
gpu cooling: water cooling
highest gpu oc so far: 300 (freaks out@311MHz)
temp of water/gas:around 22c
highest memory oc so far (w/wo artifacts): wo 244 (freaks out@253MHz)
vgpu: 2.17
vddr:n/a
vref: n/a
mods(describe the mods you did): vgpu
highest score(madmark link):
highest score(futuremark link):8880
CPU
cpu: barton 2500+
cpu oc: 9.5*242 2299Mhz
cpu cooling: air
vcore: 1.625
Mainboard
mainboard: abit nf7-s 2.0
fsb oc: 242
chipset timings (cpu interface enabled/disabled for example):cpu interface enabled
nb cooling:standard heatsink
sb cooling: n/a
mosfet cooling: ramskins
chipset voltage: 1.5
Memory
memory: ocz el 3700
memory oc: 242
memory timings: 11-2-2-2
memory cooling: standard
memory voltage: 3.1
PSU
psu: q-tec 550
12v: 13.03
5v: 5.40
3.3v: 3.46
Software
operating system: win2000
sp: sp2
driver: 3.08
ocing utility: 3dwizzard
Temp
roomtemp: around 20c
casetemp: +/- 25c
cpu temp: 30c
strange thing were is that i've got some extra 40Mhz on the core but it just gave me 128marks more than using the core at 260!
1- maxed out the card 2-i still think my score is too low @300/244 it should gave me at least 9k
after all this contest was really really funny, i luv it, i didn't had lot of time to play with the card just started beching this tuesday( board went to rma in december and just got it back last monday ) but i stiil had time to do a score on air and on water too bad i didn't had time to play in the xtreme category with my porrmy hehe gotta go for now i have to enter another ccompetition this time here in portugal hhehe, i'll see you guys in the next xtreme systems competition!!! until then take care!
system pics here:
