Results 1 to 4 of 4
Thread: [News] Philips debuts 40inch curved, 4K monitor
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    http://www.kitguru.net/peripherals/m...ed-4k-monitor/
    If you like to sit a little back from your monitor, or just prefer one giant screen to a couple of smaller ones, Philips new monster 4K display could be right up your street. The 40 inch panel has a gentle curve to it and features very high contrast ratios for bright and colourful images.
    Built using a VA LCD panel with W-LED backlighting, the display features a full 4K resolution (3,840 x 2,160) in a 16:9 ratio, stretched across its full 40 inch panel. It also features a super-wide viewing angle of 178 degrees vertically and horizontally, thanks to what Philips called its ?optimised pixel management technology.?
    Colour wise, the Philips BDM4037UW supports 85 per cent of the NTSC gamut, thanks to hardware enhancements Philips has made with its ?ultra wide colour? feature. Response time is listed at 4Ms, with a ?smart contrast? ratio as high as 20,000,000:1. It is capable of 60Hz refresh rate when using DisplayPort.
    I am Xtreme
    Dec 2008
    France
    Finally out! I've been looking forward to it for a while.
    It's a VA panel, so the contrast should be great. Looking forward to the reviews!
    Donate to XS forums
    Xtreme Mentor
    Apr 2003
    Ankara Turkey
    For monitor 16:9 can be 34" max if you force it. Lager than that 21:9 IMO
    When i'm being paid i always do my job through.
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    Wow that's a bargain! Only e590!
    If they offer a GSync one for $1k, I think that will handily steal best gaming monitor from the Predator x34.
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
