http://www.bitsandchips.it/english/5...-new-x86-uarch
2x fps in games or close to it or no upgrade!!
As a response to Zen?
Likely Zen *Greenland* and, ARM.
All the article really says is Ontel is deprecating some x86 SIMD instructions ... to save die space ?
It's not a big deal but Chipzilla is losing the transistor density wars. ARM cores are silly-small but at the sacrifice of FP and SIMD. Transistor density of AMD's 28nm SHP process (GlobalFoundries) is not dissimilar from Ontel's 14nm.
And presumably, the Zen APU will be a SIMD monster, building on AMD's vision of the shaders functioning as a "SIMD engine array" -- on top of quad DDR4, unified memory, HBM2, et. al.
It may not beat the fastest or the "best-est" but that's a fancy uArch, fer sure.
amd cpus will be dead by then. New arch will replace the current in both per/price/features.
What makes you think AMD's CPU dept will be dead by 2020?
history
Not sure about the dates given.
I thought the current roadmap was (at least for desktop): Kabylake (2017), Coffeelake (2018), Icelake (2019), Tigerlake (2020)
With indications pointing towards Cannonlake being a Laptop/mobile only part in late 2017.
After 2020...so like 2021...that's 5 years away, lots could change by then...hopefully they solve whatever problems are preventing them from going from 10nm and then 7nm first.
Intel Core i7 7700K | MSI Z270 XPOWER G.T. | EVGA 1080Ti SC2 | 16GB DDR4 G.Skill Trident Z 3200 | Samsung S27A950D | 3 x Samsung 850 EVO (250GB, 2 x 2TB) | EVGA Supernova P2 1200w | Coolermaster Cosmos II
Intel already has a response to Zen. I would say it's closer to a response to the rise of ARM processors. But mostly Intel needs to stay relevant. Their current architecture is good but old.
Intel can't afford to let AMD die. They need AMD to protect them from antitrust laws.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
x2 Samsung 850Evo 500GB
x 1 500 Samsung 860Evo NVME
Swiftech Apogee XL2
Swiftech MCP35X x2
Full Cover GPU blocks
360 x1, 280 x1, 240 x1, 120 x1 Radiators
CPUS, NOT AMD.
Dont turn the sentence other way around. AMD is dead on desktop market, their shyty gpus like VEGA which is 10% over 1080, best case scenario while burning from power draw/temp.
AMD crap will have 3 years till Intel comes up with new sh!!!t.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
Swiftech Apogee XL2
Swiftech MCP35X x2
