Class #4
gpu cooling: MicroCool Northpole
highest gpu oc so far: 274
memory cooling:none
temp of water/gas:
highest memory oc so far (w/wo artifacts): 244
vgpu:stock
vddr:stock
vref:stock
mods(describe the mods you did):
highest score(madmark link):
highest score(futuremark link): http://service.futuremark.com/compare?2k1=7555332
cpu: AthlonXP 1800+
cpu oc: 2300Mhz
cpu cooling: Swiftech MCX462-V
vcore:1.6v
mainboard:ABIT NF7-S v2.0
fsb oc: 200MHz
chipset timings (cpu interface enabled/disabled for example):
nb cooling: Vantec IceberQ Cu
sb cooling: Al Passive
mosfet cooling: Chipsinks
chipset voltage: 1.7v
memory: Corsair XMS3500C2
memory oc: 200Mhz
memory timings: 2-2-2-6
memory cooling:stock
memory voltage: 2.7v
psu: Sparkle 350W
12v: 11.73
5v: 5.13
3.3v: 3.34
operating system: XP
sp: SP1a
driver: 3.08
ocing utility: SiS
roomtemp: 19C
casetemp: no case
cpu temp: 34C
