Results 1 to 7 of 7
Thread: Power Supply for x3 GTX 780 TI's
    Aug 2008
    Doing a re-fresh and replacing 3 285GTX's (205 Watt) with 3 GTX 780 TI's (250 Watt) and I'm concerned my PSU won't be up to the extra load. Running a Silverstone OP1000W (80 Amp 12v rail).
    From my personal estimate, power draw from CPU and GPU are at best 75ish amps and at worst 80+, not including the case fans and D5 pump. Used this tool to calculate power requirements: http://outervision.com/power-supply-calculator and came up with 1187 W requirement at stock speeds and 1529 W requirement overclocking CPU/GPU's Whats a reasonably good PSU (not the best/most expensive) that can run the below setup without being pressed too hard?
    -Asus P6X58-E Pro or Asus Rampage II Extreme (not sure yet)
    -Intel i7 965 - 130w, 11 amp - Plan to run at 4GHZ @ 1.4V (where it runs stable currently)
    -x3 GTX 780 TI - 250w, 20 amp (x3) - Plan to run at 1200ish core (107% power - ~270w and 22.5 amps each)
    -x4 HD's (x2 10k and x2 7k rpm)
    -x1 SSD
    -D5 water pump (cooling CPU and all 3 GPU's)
    -30w / channel 6 channel fan controller x 5 120's (360 and 240 rad) - 15 amp max
    -x2 200mm fans
    -x1 140mm fan
    -x1 DVD
    Thanks!
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    x2 Samsung 850Evo 500GB
    x 1 500 Samsung 860Evo NVME
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Full Cover GPU blocks
    360 x1, 280 x1, 240 x1, 120 x1 Radiators
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    my two 980Ti + 5820k was only pulling 700W off the wall on full load, but on those psu calculator it stated it would pull 750w.
    so a 1.3k psu should be enough for you...
    would recommend those G2/P2 EVGA psu's, they come with 10 years warranty too.
    Aug 2008
    The G3 looks impressive and is going for $180 on amazon; not bad.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Mar 2006
    Tropics
    oh they're out now ? nice..
    Aug 2008
    Quote Originally Posted by StyM View Post
    oh their out now ? nice..
    This one, right?
    https://www.amazon.com/EVGA-SuperNOV...ywords=EVGA+G2
    Oh, meant the G2. 108amp 12V should be enough I would think.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Mar 2006
    Tropics
    yup, wait till amazon has it on stock.
    don't buy from third party sellers.
    Aug 2008
    Yeah, I only buy Prime. It'll be a few days before the new case comes in and a few more days to plan out how I'm going to mount everything so I have time.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
