+ Reply to Thread
Results 1 to 4 of 4
Thread: 2500+ barton OC question
    Nookie420
    Guest
    How far do you think this barton will go?
    230x10 with 1.8vcore is totally stable, haven't tried working the voltages down, but my temps will stay god up to 1.85vcore, anything higher and i'm getting close to 50C loads and i dont dig 50C.
    May 2003
    Edmonton Alberta
    0
    What ram you using? Voltage? Mobo?
    Xtreme Mentor Hell-Fire's Avatar
    May 2003
    Engineering Lab - NCSU
    0
    If thats the stepping on the chip that is listed in your Sig, then you have a decent chip imho.
    Mine was similiar stepping and did 2.6GHz on air..not fully stable, but stable at 2455mhz.
    I like my women the way I like my processors...naked.
    I am not the HellFire that writes bios files. I work strictly on voltage modifications.
    Nookie420
    Guest
    i got DFI infinity mobo, and Mushkin black level 2 bh-5 pc3200, running it at 3.3v in bios 245fsb as of right now, 9x multi, temps are good, 1.9vcore, 35c cpu, 32c sys temp while browsing around, i was gonna do some benching for stability but i just got reminded i have to get up early...
+ Reply to Thread
