http://www.guru3d.com/news-story/tes...-in-white.html
Tesoro released the white color edition of its SharurSE Spectrum gaming mouse. Coming in a flexible ambidextrous design (left- or right-handed), this ergonomically-designed mouse is equipped with 6 fully programmable buttons.
Not only that, this compact and lightweight mouse also comes with customizable 16.8M RGB color lighting in three different color zones, a 64KB of onboard memory, 1000Hz ultra polling rate and durable Omron switches in the left and right mouse buttons ? rated for 10 million heavy-duty clicks. It features a high-precision optical sensor of up to 4000 DPI and a gold-plated USB connector (braided cable length: 2M).
Tesoro?, a leading designer and manufacturer of high-tech gaming hardware, announced the launch of the SharurSE Spectrum, a gaming mouse designed to fit all users with an ergonomic, highly versatile tool for both the gaming and office environment. The predecessor to the original Sharur Spectrum, the SE version comes in a white build which allows it?s full 16.8 million RGB lighting to truly shine.
Customizable 16.8M RGB color lighting
1000 Hz Ultra polling rate
64KB Onboard Memory
6 Fully programmable buttons
4 level OTF resolutions up to 2000 dpi
10M heavy-duty clicks
Ambidextrous ergonomic with Soft-touch finish
Reset Hotkey
Versatile Lighting effects
2-meter braided cable
Gold plated USB plug
Size: 124 x 67.5 x 39 mm
Weight: 85g
Compatible with Windows XP / Vista / 7 / 8 / 1
