Results 1 to 3 of 3
Thread: How to replace headphone connector ATH-A900TI headphones!?
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    hey guys the connector on the end has snapped 'my nephew'. Any idea which connector i need as i was told i need a 'trrs' ?, wouldn't a normal mini trs do the job or am i missing something?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    go to your local music store and pay for them to replace the cable. you just need a normal stereo cable with 2 grounds, but you have to solder it in and i would not want to do that since it is a very small pad and not worth the risk. you may also want a short cable with a break away if they have to do the whole thing and not just replace the end.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Guru
    Jun 2010
    Quote Originally Posted by zanzabar View Post
    Hey mate i ended up getting my dad to fix it, so far seems loud and working.. I want to purchase a new sound card that will maximise these headphones performance, im currently using the old X-FI forte 7.1 sound card. What would be a better sound card for audio/gaming then the Forte?
