Results 1 to 16 of 16
Thread: R9800P Sapphire black PCB vmods help, please...
    Xtreme X.I.P.
    Dec 2003
    hi to all modders,
    let me get straight to the point...
    so i have this R9800P from Sapphire... 9700-style black PCB OEM Sapphire's own design (not ATI OEM Sapphire) with Samsung 2.86ns memory rated at 350mhz and capable of 400mhz.
    i finnaly took zalman heatsink off this thing to prepare it for mods...
    unfortunately, as us see, it has different layout...
    can u guys help me with modding this thing and finding vagp a vmem checkpoints...
    i have some close-up pics here:
    left side, middle, right side
    under quite loud air-cooling with delta 80mm this board does 450core/400mem with absolute minimum of artifacts but i would like to make it work a bit harder
    any help would be greatly appreciated
    EDIT: I know i can solder wire to pin20 as ground and then pin18 to trimmer (for vagp) and pin5 and pin7 respectively (for vmem) but i would rather avoid that as my hands are shaky and i'm not a soldering-pro...
    I work for Corsair Components, Inc.
    Xtreme X.I.P.
    Dec 2003
    oh man, that sucks...
    i just started tracing in search of vgpu and vmem alternate soldering points.
    good news is that vmem seems to be the same as on reference board...
    bad news that vgpu seems to disappear under that stupid heatspreader with sticker or whatever that is! i wonder if i can remove it safely...
    but still looking for voltage checkpoints... guys, please, help me out here...
    Xtreme X.I.P.
    Dec 2003
    i think i got it figured out..
    too bad that alternate vagp soldering point definetely sits under that aluminium plate/heatsink.
    ok, went thru all exposed caps' legs on the board and measured voltages...
    here's what i got for voltage checkpoints
    it looks like default vagp is 1.71v. three caps show same voltage. is fan ground good idea?
    also it seems like vmem checkpoint (2.80v) is also here.
    and here's on vmem side...
    i assume that 1.397v is vref since it's exactly half the vmem, right?
    i guess i'll be preparing for some soldering very soon...
    see ya guys later...
    Jul 2003
    Denmark Frederikshavn
    Nice work d00d ! I will be waiting eager to see how high you can clock this card!
    -=Back In Business=-
    Dec 2002
    Tempe, AZ
    that vmem spot, the solder pad. the pad all the way to the left of the 4 in a row, that can be used as ground too.
    NF7 | Mobile 2400+ | 256MB Twinmos PC3200 BH5 | 9800 PRO | 23384 6989
    MY HEATWARE
    Xtreme X.I.P.
    Dec 2003
    ok, i'm done so far...
    vgpu
    vmem
    unfortunately, other ground points thatm pin on those chips didn't work? anybody knows why?
    fan header at vgpu with VR maxed out on resistance gave me 1.38v... decreasing resistance gave me decreasing clock speed... and eventually not been able to boot to windows at 1.06v
    weird thing is that vmem checkpopint shows always 2.80v no matter how i turn the trimmer (need help here please) but after i decrease resistance (about 6 turns) screen gets corrupted and icons dissapear.. so seems like i raised voltage...
    FIRST impression with vmem VR maxed out and vagp at 1.75v i need to clock down my memory to get rid of artifacts.... i'll get some more testing there...
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    That check point you read 2.80v is not the VDD (mem), that's VDDQ.
    Xtreme X.I.P.
    Dec 2003
    yeah, i know there's something wrong here.... could you tell me where this vdd checkpoint is.... i raise vdd to get rid of artifacts but don't know how high it is...
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    that point you read 3.335v. That's the one for VDD.
    Xtreme X.I.P.
    Dec 2003
    wow... so this thing was doing 3.35v stock??? damn, no wonder it went to almost 390mhz artifact-free when i got it... so this checkpoint reads 3.70v now...
    unfortunately i can't go back to my previous mem clock of... even at 3.7v i need to lower to 350 to have no artifacts... how to fix this thing... ? if i remove vdd mod would that work ?
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    Well, you may try the vddq mod. That should help you mem clock. You'll have to remove the plate from the back of the card to get ot the chip for the vddq mod. Be very careful when removing that - see pic below why.
    The area highlited in the pic is the chip for the mod. solder pin 1 (look for the mark on the chip - the small hole) to pin 4 via 50k trimmer. Lower resistance for more volts. You have 2.8v now, you may try 3v.
    Xtreme X.I.P.
    Dec 2003
    oh man, that sucks coz i have those trimmers glued to it (well to electric tape so i got lucky here) and wires are very short... is that gonna help, have u tried it and succeed ?
    Xtreme X.I.P.
    Nov 2003
    Keller, TX
    I haven't tried it yet, you see why. I'm just waiting for the new chip to get here, then I'll do it. I am modding the whole thing: vGPU, VDD, Vddq, Vref.
    Xtreme X.I.P.
    Dec 2003
    oh, i remember that post... your chip came of with the plate. i know it's glued on two chips... i'll try that anyways... i'm off today so plenty of time to experiment...
    Dec 2002
    Jersey City, NJ USA
    also one thing I have learned is when you mod your vgpu the extra heat also heats up the ram, and will lower your ram clocks. That is probably why you had to lower your ram clocks to get rid of artifacts.
    Also I can't believe that ram is at 3.3V stock! On a BBAti 9800pro the ram is at 2.68v That is just incredible.
    Just be careful though. Going to high on the ram is one of the biggest killers of cards.
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
    Xtreme X.I.P.
    Dec 2003
    what i was thinking that maybe vddq is gonna help... i'll give it a go next week and see what happens...
