Results 1 to 2 of 2
Thread: Pre-orders now open for new Samsung Gear VR
    Join XS BOINC Team StyM's Avatar
    Mar 2006
    Tropics
    http://www.kitguru.net/components/vr...msung-gear-vr/
    Rumours circulated earlier this week that Samsung and Oculus had a new Gear VR headset in the works and now those have proved true. Starting late yesterday, both companies made a second edition Samsung Gear VR headset available to pre-order in the U.S. for $100.
    The most obvious difference with this second edition Gear VR, is that it?s black. The original edition was stark white, which while making it stand out, did give it a bit of an exaggerated profile. In comparison the Gear VR 2 is far more understated in matt black and looks much more like the other commercial VR headsets we?ve seen launched in the past few months.
    Don?t expect a massive visual improvement over the first edition, as although this one supports the new Galaxy Note 7, that has the same resolution as the Galaxy S7 (2,560?1,440). However due to being larger, it does have a lower pixel density so using that handset may look slightly worse.
    The field of view on the new headset is slightly larger though, bumping up from 96 degrees diagonally to 101 degrees. There?s also a new interface system, with a better touchpad and button placement. There?s also a new USB Type-C connector to make it compatible with the Note7, though theoretically this could be used for further expansion in the future.
    Oct 2006
    Price is right unfortunately I don't have a Samsung handset.
    say it ain't so Joe............SEO Services SEO Business
