http://www.guru3d.com/files-details/...-download.html
You can now download the new AMD Radeon Software Crimson Edition drivers release 16.7.3 driver which adds improved power distribution for the Radeon RX 480 as well as performance improvements.
Radeon Software Crimson Edition is AMD's revolutionary new graphics software that delivers redesigned functionality, supercharged graphics performance, remarkable new features, and innovation that redefines the overall user experience. Every Radeon Software release strives to deliver new features, better performance and stability improvements.
Performance Improvements:
Rise of the Tomb Raider? performance increase up to 10% versus Radeon Software Crimson Edition 16.7.2 on Radeon? RX 480 graphics
FIXED ISSUES
  • Overwatch? may experience an application crash on some Radeon? RX 480 configurations when using AMD Crossfire mode.
  • Vulkan? information in the Radeon Settings software information tab may display an incorrect version.
  • Radeon WattMan may retain settings of an overclock after it has failed. If you have failed an overclock with a system hang or reboot.
  • Hitman? may experience graphical corruption when the game is set to use DirectX?12 API and using zoom with weapons.
  • Total War?: Warhammer may experience minor graphical corruption in some map textures on AMD Radeon R9 380.
  • Flickering may be observed in Rise of the Tomb Raider? on some AMD Crossfire configurations using the DirectX?11 API.
  • Changing settings in Dragon Age Inquisition? with the Mantle API may result in an application crash or driver recovery.
  • DiRT? Rally may experience flickering terrain in some races when the advanced blending option is enabled in the games settings page.
  • Display may exhibit a minor flicker on Radeon RX 480 when Freesync is enabled on a games launch or exit.
  • Shadows may experience rendering issues in DOTA2? when using the Vulkan? API.
  • Textures may experience holes or gaps in DOOM? when using the OpenGL API and three display AMD Eyefinity configurations.
  • Need for Speed? may experience flickering on some light sources in AMD Crossfire mode.
http://www.guru3d.com/files-get/amd-...ownload,1.html
http://www.guru3d.com/files-get/amd-...ownload,2.html
http://www.guru3d.com/files-get/amd-...ownload,3.html
http://www.guru3d.com/files-get/amd-...ownload,4.html
