Results 1 to 2 of 2
Thread: My Corsair Gaming Build
    Nov 2005
    The Berkshires, Massachusetts
    Case: Corsair Air 540
    CPU: i7 4930
    MB: EVGA X79 Dark
    GPU: GTX 690
    Ram: 16GB GSkill Trident
    PSU: Corsair AX1200 w/custom blue sleeving
    Tubing: Monsoon Hardline
    Fittings: Monsoon Chaingun
    Res: XSPC 140 W/D5 pump
    Rads: 2x XSPC 280's
    Fans: 5x Corsair 140mm
    Fluid: Feaser 1
    Oct 2002
    Front of computer
    Not bad, not bad at all...
    I had this case prior to my current one and it served me well.
    I was able to cram a 360 RAD in the front with a little modding on the HD tray's.
    Other than that, I had no complaints with the case beyond it's footprint and the limitations that came from that in terms of desk placement.
    Great job btw.
    Step aside, and you won't have to feel the awesome wrath of my mustache!
