Results 1 to 7 of 7
Thread: Polycold Cryotiger -203c on ebay for under $200
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    A small Cryo compressor, a good started project for someone who wants to venture down this path. Low wattage, low price but should be fine to learn.
    Or... Suck the gas out and use in a cascade. Several on ebay at this price. Polycold gas blend as awesome and very expensive.
    http://www.ebay.com/itm/IGC-Polycold...item1e956a6c14
    PDF:
    http://instrumentation.obs.carnegies...G_Brochure.pdf
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    -150c Club Member
    May 2005
    Northeast, USA
    Sadly these aren't the mythical unicorns they look like. The box is just a compressor condenser oil separator. The hoses and cold head provide all the heat exchange and capillary lines. And while the gas charge is present, the cost doesn't support it... sadly I know this because I have one on the shelf.
    On the other hand. If someone grabs this I will help you find a cold end and hoses if possible, or would be happy to help build one.
    If you have a cooling question or concern feel free to contact me.
    Jun 2002
    Las Vegas
    I am a bit more adventurous, I would suck the gas out as the cheapest polycold charge will set you back $700
    I have a larger CTI with helium compressor.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    -150c Club Member
    May 2005
    Northeast, USA
    The charges are certainly expensive!
    I think we can make that mix for far less though. And even less still if we look through Mytek work with hydrocarbons.
    Jun 2002
    Las Vegas
    You and I can do our own blends for much cheaper, this was a less expensive option for parts and gas.
    It is a full condensing unit with brazed plate heat exchanger built into an autocascade single compressor with custom gas mix.
    I think Cryotiger is PT50 ~ $650 per charge
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Xtreme 3D Team
    Jan 2013
    Dayton Ohio
    So basically one could build a line set for this and have a charged autocascade? Assuming it is fully charged.
    -150c Club Member
    May 2005
    Northeast, USA
    You'd need a specialized vacuum sealed evaporator system. And you'd get a -200C at 10watts.
