The Antarctica WaterChill CPU block
To demonstrate asetek's position as the leading manufacturer of water cooling solutions and to fulfil the demands from the most hardcore enthusiasts, asetek has released a new and EXTREMLY POWERFUL CPU COOLING BLOCK: The Antarctica CPU Cooler Block.
The Antarctica CPU cooling block represents the following qualities:
BEST PERFORMANCE & OVERCLOCKING POTENTIAL IN THE WORLD
NEW IMPROVED BLOCK WITH STREAM CHANNELS(tm) FOR BETTER WATER FLOW AND HEAT REMOVAL
TWO WATER OUTLETS FOR MORE AGGRESSIVE WATER FLOW
NEW IMPROVED LID AND PUSH-ON FITTINGS FOR EASIER ASSEMBLY
STRONG VISUAL IMPACT FOR CASE MODIFICATIONS
SUPPORTS INTEL S478, AMD SOCKET A (S462), AMD ATHLON FX (S939/S940) & AMD ATHLON64 (S754)
and also
WaterChill XEON CPU cooling block for workstations and servers
The WaterChill CPU XEON block is characterized with:
MAXIMUM COOLING CAPACITY FOR COST-EFFECTIVE & ENHANCED PRODUCTIVITY
MASSIVE NOISE REDUCTION & SIGNIFICANTLY IMPROVED WORKING ENVIRONMENT
RELIABILITY & OPERATIONAL SECURITY
ASSEMBLY EASE
UNIQUE SAFETY & NOISE CONTROL FEATURES
More information can be found here
