Amd Nvidia/Ati -3dmark06 scorebord revisted
asus L1N64-ws or /b depending on bios chip
4x1gig 8500 gkill bpk
2x opteron 8224 @ 3.8ghz
http://www.xtremesystems.org/forums/...&postcount=236
vga= 8800gt
winxp pro
custom chiller -31 water
2x dtek fuzions
bix3-with x3panaflo hi output
antec 850 quattro
heat under msimax abitmax and dfimax
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
place holder 2
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
Just some suggestions, you appear to have Hynix MFR from Corsair.
cache 1.5v 4500Mhz cache voltage doesn't have much of an impact on temps at all.
memory voltage closer to 1.6v for CL12 and lower trfc to at least 266
latency will drop below 50ns and bandwidth will go over 70k
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
hey fugger its v4.23 samsung chips but ill still try the other suggestions thanks
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
Very nice. How do you like the board. I have been thinking about grabbing one myself.
still learning the board myself post code BD after a cold boot is common and pressing reset once or twice most times boots it back up
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
testing the 5930k is about the same limits as the 5820k but the mb doesnt panic as much when changing things around memory has been booting constantly
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
still u are lucky for chips. I mean, I know 5960X are harder to stable OC than 5930/5820K, but I was not much lucky, my i7-5960X topped at 4350 MHz in stress AIDA test
Im interesting, what will change with your 5930K and some issues.
ROG Power PCs - Intel and AMD
right off that bat i can tell you that memory issues are less common maybe has better imc. needed this cpu because i want my raid card to work without using the pcie riser cable because of the 4th x16 slot being disabled.
also i retested vantage and noticed worse cpu scores seems like its throttling down it will be at 78 ops then creep down to 65. remounted twice same issue extra lanes must make it run hotter lol
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
wow friend! 5 GHZ 32M...What was your temps inside or outside?
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
vga= 8800gt
winxp pro
2x dtek fuzions
antec 850 quattro
