Results 1 to 4 of 4
Thread: most quiet 1/3 compreessor ?
    Aug 2010
    hello
    what is the most quiet 1/3 compreessor brand you know ?
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Americold if you can find one.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Aug 2010
    i have notice that Samsung are the best i know
    danfoss is very noisy... NL11F/FR11G is terribly noisy...
    is Americold are better with noise level ?
    i realy want to find the most queit 1/3 compressor on earth
    so if anyone come across a very quiet compressor drastically quiet
    i would be super happy to know ....
    Oct 2011
    There is no such thing as a " fully silent " 1/3 cv compressor, it's actually quiet a lot of power for a little SS system !
    NL11F is a little noisy because it works at low pressure, every compressor working at low pressure make a little noise, you have to deal with it.
    However, you can add foam insulation to cover the sound. I worked with hundreds of compressor, from 1/12 hp to several hp's, and no one is fully silent. Try TEC's if you don't want any vibration
