Results 1 to 4 of 4
Thread: Best GTX 980 for mild Overclocking/Performance.
    May 2006
    Texas
    Question Best GTX 980 for mild Overclocking/Performance.
    I am looking at getting a pair of 980s for SLI in my system, maybe a 3rd card for dedicated Physx.
    1) Which 980 card should I get. (Budget is $1500 total) Looking at:
    a) http://www.newegg.com/Product/Produc...-079-_-Product
    b) http://www.newegg.com/Product/Produc...-834-_-Product
    c) http://www.newegg.com/Product/Produc...-682-_-Product
    2) If I was to go with a dedicated card for Physx, which would you recommend. I know it would probably be an older/cheaper one.
    3) Also; if I am somewhat under-budget enough, I was debating adding a Samsung 850 Pro 512GB SSD to the order. Got a few Newegg coupon codes that would keep it close to the $1500.
    Thanks in ADVANCE.
    PI in the face
    Nov 2008
    gaming or giga looking at the cooler
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    Mar 2010
    Just received my 980 SC ACX from evga couple hours ago hitting 1580Mhz core 8000Mhz RAM max temp of 70c
    Just ordered a 2nd one from them hope its as good.
    I would get them from EVGA they will both prob be from the same batch so good chance they will be on par with one another.
    Nov 2014
    Quote Originally Posted by demo23019 View Post
    Just got this card also, 74.4 Asic and 1580 / 8000
    http://www.3dmark.com/fs/3274874
