Of all the things I've lost in life, I miss my mind the most.
System:
CM 690 II Advanced case v.3
// ASUS Sabertooth Z77 Motherboard
// Intel 15-3570K CPU
// 32GB (4x8GB) DDR3, 1600 Kingston Hyper X Black memory
// 2GB EVGA GTX 660Ti video card
// ASUS BW-14D1XT 14X Internal Blu-Ray Burner - BDXL Format
// Corsair AX750 PSU
// Corsair AX750 individually sleeved cable set
// 2x Samsung 840 128GB SSD
// 2x Western Digital Caviar Black 1Tb 7200 RPM SATA drive
// 24" Samsung HDTV Monitor
Watercooling Loop:
XSPC Raystorm CPU waterblock
// XSPC Razor GTX670 GPU waterblock
// XSPC Razor GTX670 back plate
// XSPC memory heat sinks
// XSPC Dual 5.25" Dual Bay Reservoir
// Swiftech MCP655 Water Pump w/ Speed Control
// Bitspower Ultimate 3/8 x 5/8 Compression Fittings
// 2x XSPC RS240 Dual 120mm Low Profile Radiator Rev 2.
// 1x 120MM BitFenix Spectre Red LED fan
// 5x 120mm Scythe Gentle Typhoon Fan[/SIZE][/SIZE]
