Results 1 to 11 of 11
Thread: How to remove kneaded eraser
    Sep 2014
    Slovenia
    Hi, just did my first dice run today, but now i want to remove kneaded eraser from the mobo, how the hell do i remove this sticky sh*t.
    Administrator
    Nov 2007
    Stockton, CA
    It should just peel right off.
    Is your board still wet ?
    What kind of eraser did you use ?
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    If there are little spots left, roll a ball of kneaded eraser and pick up the spots, it should be pretty easy that way.
    PS: Feel free to join the XS HWBot team if you want!
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Sep 2014
    Slovenia
    I used conte a paris, the only type they had in the art store. I thought that it should peel off but this one sticks like glue :/ my board is not wet i stoped benching 4 hours ago. Now i put the board in the freezer i think the temperature will make it harder and easier to remove.
    Administrator
    Nov 2007
    Stockton, CA
    This stuff ?
    http://artworldonline.co.uk/drawing/...ft-eraser.html
    Not sure about the soft part, the stuff I use is not that soft. I microwave it for about 20 seconds to get it pliable so I can form it easy.
    Sep 2014
    Slovenia
    Yes this is it, i really dont recomend this stuff if you want to remove it, i didnt remove it completly there are a lot of small pieces on the board in corners and so, i really hope that i will never have to rma the board. I cleaned it for two hours. This one sticks like cheving gum, it sticks really hard and is really soft, good for insulating a pain to remove. I will read about this erasers and bought another brand and toss this one in a bush so nobody will stick to it
    Xtreme Cruncher
    Jun 2009
    Bombay , India
    Faber Castell is the way to go rocks !
    Intel Core i7 3960x | 3x Intel Core i7 980x | 3x Intel Core i7 920 | 2x Intel Core i7 2600k | 2x AMD opteron 6282 SE | 3x Asus Rampage II Extreme | 2x Asus Rampage III Extreme | Asus Rampage IV Extreme | 1x Gigabyte X58A-UD7 | 2x Asus Maximus IV Extreme-Z | Asus KGPE-D16 | 3x 6GB DDR3 Corsair Dominator 1600 Cl7 | 1x Patriot Viper II 6GB 2000 Cl8 | 3x Corsair Hx1000 | 4x Corsair Ax 1200 | 3x Antec 1200 | 4x Corsair Obsidian 800D | 2x Intel 80Gb G2 SSD | 4x Kingston HyperX 120GB | 2x Vertex 2 120GB | 2xWD 150GB Velociraptor + 1x WD 300GB Velociraptor +5TB | Msi Nvidia Gtx 295 | Msi Ati 4870x2 OC Edition | 2x Msi Ati 4890 OC Editions| 2x Sapphire Ati 5870's| Sapphire 5970 OC Edition | 2x Msi Gtx 460 | 3x Sapphire 6970 | 3x Asus Gtx 580 | 3x Asus 7970
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by Toolius View Post
    Yup that's what I use.
    Sep 2014
    Slovenia
    Thanks, i will order some online for my future sub zero misions need to learn to beter insulate the board but in another thread i need to put my pc back together.
    Apr 2006
    Bulgaria
    I've used both Faber Castell and KOH-I-NOOR, but I think Faber Castell is the best.
    X6 1090T (1010MPMW) @ 4267MHz 1.44V NB@3229MHz 1.33V | Asus Crosshair IV Formula | 2x2GB Corsair Dominator GTX2 @ 1845MHz 6-6-5-17-22 1T | Asus HD4890 @ 1050/4800 | Corsair HX850W | HAF 932
    EK Supreme HF | EK-FC4890LT | MCP655 + Koolance D5 Top | ThermoChill PA120.3 + 3x Enermax Magma | XSPC Bay res | Masterkleer 1/2" UV Red
    Sep 2014
    Slovenia
    Got em today, they are 3 times biger and 10x less sticky than my previous one...
