X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 6 of 6
Thread: A quick and easy Sandy Bridge question
    Oct 2004
    Hey fellas. It's been years since I built the system I'm currently using and followed pc hardware, so you could say I'm rusty + out of the loop.
    I had no need to overclock my 2500k since I had it paired with a GTX 570 and that limited my FPS in games more than anything. With my new GTX 970, however, I wanted some more cpu performance.
    I'm at 4.5ghz right now, with 1 volt at 1600mhz idle, 1.3 volts at 4500mhz load. However, my voltage will spike to 1.344 according to hwmonitor. I just wanted to make sure that this spike is still well within safe limits for the 2500k.
    Thanks! And sorry about the noobie question.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Yep, safe. It should like SVID is working and adjusting voltages on the fly, it is normal.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Oct 2004
    Awesome!
    Thank you FUGGER!
    Oct 2004
    Hey guys. I know I said it would be quick and easy... But I ended up having some issues with the stability of that clock and want to check on my new settings.
    I'm now just running straight 4.4ghz, all turbo and power saving features disabled. This is with LLC level 6 and 1.330 volts selected in bios on a GB P67-UD5 v1.0.
    I've already tested and LL6 is definitely best for this voltage on my board (5 drops too much, 7 goes too high on load).
    My volts are ranging from 1.308 to 1.356. I wanted to ask A: is it normal for this board to have so much variation in voltage? and B: Are peaks into 1.356 safe for 24/7 usage?
    Thank you! And, again, sorry for the dumb questions. I just don't want to have my chip die before I'm ready to build a new system.
    Dec 2007
    Texas
    Yep you should be fine.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Oct 2004
    Thank you!
    I think my old C2D era DFI must have spoiled me for voltage regulation then. It was so rock stable... Man I miss that board...
