Results 1 to 8 of 8
Thread: one question
    Aug 2010
    one question
    hey
    can i add a 1/4 cooling coil that's
    4 meters long to my ss ?
    http://s14.postimg.org/ux5e3hvr5/cooling_coil.jpg
    i am using a 3/8 condensor and a 210w compressor
    will a 1/4 pip in the middel of everything won't make any problems ?
    someone told me that i must use at least 3/8 thickness...
    i want to give the condensor some extra help
    but if i'm gonna use 3/8 coil it will be too much weidth for me i don't have a room for bigger weidth then 8 cm....
    that's why i want to use a 1/4 coil that is naturaly more
    narrow
    so is that ok to use 1/4 or not ?
    thankx ppl
    I am Xtreme
    Mar 2005
    It will be fine on the high side. Before or after the condenser ? What is your current sub-cooling?
    Walt
    The Laws of Thermodynamics say:
    Zeroth Law: "You must play the game."
    First Law: "You can't win."
    Second Law: "You can't break even."
    Third Law: "You can't quit the game."
    Do you wanna Play Thermodynamics ???????? I forgot "you must"
    Aug 2010
    before the condenser...
    i did't buid it already
    so you say it's ok ???
    it won't harm right ?
    Xtreme Cruncher
    Nov 2005
    Rhode Island
    1/4" is a bit small, but I don't think it would hurt anything in a small SS.
    Fold for XS!
    You know you want to
    Aug 2010
    Ok thanks man i will add it...
    One more question my friend
    Like to know your opinion
    What would give a better OC performance to the cpu
    A 200w compressor or a hi quality liquid cooling unit?
    CPU is Intel 4th generation 95W
    the SS will be able to load 300w and stay on -20....
    Xtreme Cruncher
    Nov 2005
    Rhode Island
    Can't answer that, sorry
    Fold for XS!
    Aug 2010
    ok thank you so much
    Xtreme Member eagle101's Avatar
    May 2003
    SoCal USA
    Quote Originally Posted by hyperionix View Post
    hyperionix hows your ss going lets see some pix .......
    Thanks Eagle101
    CrossHairV-Z 9590 cpu-OC
    SSD Ocz RevoDrive3 X2 Raid0 PciE
    -51c Cpu SS Phase.Change Cooling
    Msi 290X Lightning oc
    1600 Watts P2 Evga Platinum
    G.SKILL Trident X Cas7 1600Mhz
    Dell U2410 24" IPS
    5.1 Sound Pro-Klipsch
