2x 360 rads + apogee GTZ enuff for 4790k ??
Looking to cool i7 4790k.
At 1.26 vlts.46 mhz on all cores this thing reaches 95C on aida system test and gives BSOD 124. Don' really believe it needs volts as much as it nedds to be cooled so what I am asking is this much rad plus block adequate for cpu or do I need new block or rad ? This has treated me well up to now .or maybe I should just delid and be done with this problem. What do you think would be best solution.
What you have should be fine. Is the block free of debris inside? Is it mounted properly?
Likely culprits:
- Lack of flow, ensure everything is pumping well.
- Bad mount.
- Bad Intel TIM between the die and IHS (most likely).
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
- You may not post replies
- You may not edit your posts
Forum Rules
