Results 1 to 2 of 2
Thread: Advice: GTX780TI OC or non-OC
    Feb 2005
    Hello,
    I have a custom watercooling setup, and would plan to buy a watercooler for the new GPU.
    As I already plan to overclock it anyway (and can usually easily do with the watercooling setup, temp-wise), should I go with the OC-edition of the card and then OC some more, or just save the money and buy the regular edition (about 100? cheaper, the price of the watercooler) and overclock it to the OC-edition or above?
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    What card exactly? KPC and Lightening's are better built cards, Asus also puts a lot of engineering in OC editions not just a better heat sink and slightly higher default clocks but built on reference design. There is some binning in OC editions too, depends on the card mfg.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
