    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 9 of 9
Thread: pureELEGANCE by Malik Customs
    Dec 2006
    PL, Bielsko-Biala
    pureELEGANCE
    Intel I5 4670K
    Asus Z97M-PLUS
    Asus GTX 780 STRIX
    Kingston Fury 16 GB 1866Mhz
    Kingston HyperX SSD 120GB x 2
    Fractal Design NODE 804
    Seasonic Platinium 760W
    Noctua Industrial 120 mm fans x 8
    Aqua-Computer Aquaero 5 LT
    BitFenix Alchemy Gold/Black Cables
    EK-Supremacy Clean CSQ - Gold
    EK-FC780 GTX Ti DCII - Acetal+Nickel
    EK-FC780 GTX Ti DCII Backplate - Black
    EK-D5 Vario X-RES 140
    EK-CoolStream PE 240
    Tygon R3603 11,2/15,9mm
    Moderator
    Oct 2007
    Oregon - USA
    uhh.... graphics card waterblocks can be hooked up like that?
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    Feb 2010
    UW - Madison
    Quote Originally Posted by Ace123 View Post
    Y'know I've seen the same setup elsewhere and questioned it... but now I'm really trying to figure out what the flow looks like and my eyes are crossing.
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    lol I'm confused as well, not sure flow would be all that good ?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Jan 2010
    Regardless Malik,
    I always love your builds and am inspired by them. This metallic accent build looks cool!
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Sure they can be used like that. His CPU and GPU block just run in parallel. The blocks have a similar pressure drop so this shouldn't be an issue w/ just one GPU. Do not do this if you are using two or more GPUs though. Flow rate through the CPU will become extremely low. Makes bleed nearly impossible.
    Feb 2010
    UW - Madison
    So at the input of the GPU block, it's essentially splitting the water pressure into GPU-destined and CPU-destined cooling?
    I am Xtreme
    Oct 2005
    Quote Originally Posted by ScottALot View Post
    Yes. About half of the water will go the one route while the other half goes through the other block. Flow rate though the blocks will be significantly lower.
    Oct 2007
    I just got mind-blown, this build is amazing. Beautiful and clean
