Results 1 to 9 of 9
Thread: comp fittings on UT60
    Oct 2005
    so alphacool made the UT60 so that swiftech .5in ID, .75 OD fittings wont fit when a fan is installed on the same side.
    Any one know if the bitspower compression can be installed on the same side as a fan?
    EDIT: ROFL even alphacool .5ID comps are 26.1mm OD, so they wont even fit!
    Intel Q6600 L727A 3.2GHz (8*400 @ 1.35v)
    Asus Maximus Formula
    2X2gb Gskill DDRII-1000
    XFX 5870
    WD 150Gb Raptor and Maxtor 250Gb DiamondMax10
    2X Samsung DVD-RW DL SATA
    Silverstone OP850
    Thermalright Ultra 120 Xtreme (lapped)
    Thermaltake Armor
    thats it, and proud of it.
    Heatware: pby5cat
    Oct 2004
    My monsoon free center compression 1/2"ID/3/4"OD fit on my alphacool monsta ...in fact I'm using 45 degree rotaries and they fit as well.
    Sorry about the pic but it's all I have on hand right now.
    M7H (1002) | i7-4790K @ 4.8ghz @ 1.366v | cache @ 4.6ghz @ 1.309v |16gb (2x8) Xtreem @ DDR3-2666 (11-13-13-35-1T) | GTX 770 | AX860 PSU
    CVF-Z (2002) | FX-8350 @ 4.6ghz @ 1.4875v | cpu/nb @ 2600 @ 1.275v | ht @ 2600 | 8gb (2x4) Redlines (996997) @ DDR3-2133 (9-11-10-28-1T) | GTX570 | 850Z PSU
    Jul 2011
    San Diego
    What size UT60? Yeah my monsoons and Koolance VL4N (fat) QDCs work on the UT60 480, the XT45 560 and the Monsta 560, the only alphacool rad I had problems with is the ST30 120 rad.
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Renton WA, USA
    use extensions (this is what im planning with my 3/8-5/8 fittings), or smaller fittings, 1/2-3/4 fittings are silly anyways that is probobly why they dont support it.
    Oct 2005
    its a UT60 240.
    I bought primochill LRT adv 1/2ID 3/4OD tubing for the build, so i need the large fittings.
    Now Im worried about my coolgate 360.
    XFX 5870
    Silverstone OP850
    Thermaltake Armor
    Heatware: pby5cat
    Jul 2011
    San Diego
    Quote Originally Posted by NKrader View Post
    While I agree that 3/4 OD are often silly, I still use them because the VL4N and QD4 come in that size. The ST30 120 even had some compatability issues with 5/8 OD on one of the ports (manufacturing variance I guess).
    Oct 2005
    Im going to notch the fan frames to make the comps work.
    XFX 5870
    Silverstone OP850
    Thermaltake Armor
    Heatware: pby5cat
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Quote Originally Posted by pby5cat View Post
    Let us know if you fix the problem , pictures , update.
    Oct 2005
    update with pictures on my build log, http://www.xtremesystems.org/forums/...led-Enthoo-Pro
    XFX 5870
    Silverstone OP850
    Thermaltake Armor
    Heatware: pby5cat
