http://hk-spot.com/review/amd-arch/AMD-Arch.html
Hope you will like this.
yes, not bad, Do you will upadte this review with next CPUs?
ROG Power PCs - Intel and AMD
Interesting comparison, we still use a few 4850e's and 505e's at work. I did expect an better ipc on jaguar in comparison to athlon64. Seems under linux jaguar performs better because most of the benchmarks made use of newer instruction sets.
http://www.phoronix.com/scan.php?pag...enom_am1&num=4
Opteron 165 vs. Kabini 5350
Which is faster?
FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
Asus Crosshair Formula 5 Am3+ bios v1703
G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
MSI 7950 TwinFrozr *1100/1500* Cat.14.9
OCZ ZX 850w psu
Lian-Li Lancool K62
Samsung 830 128g
2 x 1TB Samsung SpinpointF3, 2T Samsung
Win7 Home 64bit
My Rig
5350 is beast, it win average against A4 Trinity APUs
I am glad of my 5350 purchase , it works nice as a HTPC for my living room.
This fact alone makes AMD look ridiculously stupid. The 5350 CPU part is as fast as AMD's Richland mobile A8 and A10 APUs.
Whatever team designed the Jaguar core, they deserve awards.
A 32nm Bulldozer module (containing 2 cores) was 30.9mm^2, while a Jaguar core on 28nm process is only 3.1mm^2.
You can probably fit six Jaguar cores inside a Steamroller module...
All while Steamroller is no faster than Jaguar sub 45w TDP
Imagine a large-design Jaguar core with 4MB L2, and dual channel memory? Clock per clock, it would probably be close to matching Steamroller in some applications.
Smile
Beema and Mullins bring the Jaguar family IPC even higher with dramatically lower power consumption. IPC of them is better than Steamroller as far as I know.
Fold for XS!
You know you want to
