Results 1 to 5 of 5
Thread: Any all in one water cooling that you actually recommend?
    Dec 2004
    Long Island, NY
    I went through 2 Swifttech H220's and sold the 3rd without even using it. Both pumps failed within a very short period of time. I know custom loops are the best way to go but are there any AIW systems out there that are worth it and actually cool well?
    When the H220 was working I had no problem getting my 4770k to 4.7Ghz 24/7 stable non-delid. Before I get my hands on a 4790k I'd like to do some more OC'ing with this 4770k. Just need a reliable AIW system.
    Thanks.
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
    Jul 2011
    San Diego
    Weird that you had two fail - I thought the H220 used a similar pump to the DDC series of pumps which should be more reliable. Maybe contact Swiftech for RMA? The H220x is about to come out so they might send you that instead and that looks very promising. The only AIO that I've personally used is the H100 on a 3770K, mine was ok though I know a lot of people had problems with them and had to RMA for pump issues also lol. Personally I only use an AIO as a "tester" or low maintenance cooling system, I wouldn't necessarily consider them reliable though even though my sample of one has been. They're not bad cooling wise if you get one with a 240+ sized radiator but won't compare to custom water cooling on higher heatloads. As you're running a 4770K your heatload won't be that high simply because 4 cores (vs a 3930K for example) and not scaling well with voltage (many 4770Ks seem to show little gain after 1.3v unless you go subambient). If you don't mind noise though you can get decent cooling on an AIO just by running high rpm fans. I think I saw an AIO with a 360 rad. If you are planning to go water soon though I'd be tempted to skip the AIO and just go water now.
    May 2007
    Hampshire, UK
    Was never a fan of AIO but that changed when I was given an Antec Kuhler 620 as part of a Gigabyte P67 motherboard promotion. I would never have bought it but when I used it I found it was great, quiet & worked well. I later purchased the Kuhler 920 & use it currently with my Z87 / 4770k & I think its great & it was very cheap. http://www.antec.com/product.php?Per=17
    Here is the 920 on full pelt keeping my old 4770K @ 4.8GHz
    http://s106.photobucket.com/user/Cra...tml?sort=3&o=1
    Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
    Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
    Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
    Jul 2011
    San Diego
    If you dislike patent trolls (http://www.techpowerup.com/202633/as...d-cooling.html) then avoid anything made by asetek which includes many rebranded units including at least some Corsair units (source: http://asetek.com/customers/do-it-yourself.aspx)
    PI in the face
    Nov 2008
    thermaltakes have been running strong for me last 1.5 years or so
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
