Results 1 to 4 of 4
Thread: How to fix source engine using only 1 cpu?
    Jan 2011
    I have a dual xeon 3ghz system with 4 threads with hyperthreading.
    Anyway Tactical Intervention only uses the 1 thread.
    So in-game the tactical intervention.exe only uses 25% in task manager
    I just want to force source engine to utilize all 4 threads because my fps would go up...
    -Intel Core i7 930 @ 4.6Ghz max (Lapped)
    -Cocage True Spirit w/ Scythe Ultra Kaze 120mm (Lapped) *Indigo Extreme* 60-70C at 4.2 - 70-80C at 4.6
    -6GB OCZ DDR3-1600 @ DDR3-1600
    -ASUS RAMPAGE II GENE
    -SLI GeForce GTX 470 @ 851Mhz Core, 1702Mhz Shader, 1875Mhz Memory @ pulling a solid 68GPixel/s and 96GTexel/s = Outperforming a stock Titan (60Gpixel/s) - 640 bit total memory width - 300GB/s Memory on the GTX470's
    -2X WD1001FALS Black Edition,2X RAID0 SEAGATE 250GB, WD 2TB
    -Lian Li PC-V354 Case - **Custom Modding In Progress**
    -Kingwin 1000W Power Supply
    -Creative Sound Blaster X-FI Xtreme Gamer w/ Audigy 2 ZS Live! Drive w/ HDMI audio & SPDIF OPTICAL Out.
    -PIONEER VSX-520-K HOME THEATER 3D HIGH DEFINITION RECEIVER
    -Dayton Audio Dayton HTP-3 5.1 Home Theater Package 12" Powered Subwoofer
    -Samsung LN40B500 40" 1080p LCD HDTV
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    The engine is only single threaded. I don't think it can be forced to use more than one thread as that would basically require a recoding of the game engine.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    c[_]
    Nov 2002
    Alberta, Canada
    In the launch options set "+mat_queue_mode 2"
    If that doesnt work then you're stuck with a single thread.
    All along the watchtower the watchmen watch the eternal return.
    Mar 2010
    Perhaps there's a way to assign every other task to the other cores so the game gets a "whole core" for itself.
