I am a little noob bastard.. no skills to extreve oc
I have all options AUTO..
I only change vcore cpu core and ram voltage and timings and more few options..
My memories is SAMSUNG DDR3-1600MHZ 2X4GB and not stable at 2200.. only stable at 2133 @ 1.45v
what is this? Row Refresh Cycle Time (tRFC) - I have auto and I see value 171
what better value should works?
what is cpu cache voltage? I have auto
MY SYSTEM: BENQ 27" LED XL2720Z | PHANTEKS ENTHOO PRIMO BLACK | EATON ELLIPSE ECO 800VA | ENERMAX PLATIMAX 750W | ASUS Z270 MAXIMUS IX HERO | INTEL i7 6700K | NOCTUA NH-D15S | CORSAIR VENGEANCE LPX DDR4 3200MHZ 16GB | MSI GTX980 GAMING 4GB | ASUS XONAR ESSENCE STX II | LOGITECH Z-5500 | SAMSUNG SSD 850 EVO 500GB | 2x WESTERN DIGITAL GREEN 4TB SATA III | ROCCAT RYOS MK PT | STEELSERIES RIVAL 300 | STEELSERIES 4HD | LOGITECH GAMEPAD F510
So before I kill me cpu, what's the highest vcore for a quick bench?
Highest I've gone is 5.2ghz @1.480vcore but it won't get into Windows, it's very close. Water cooling with tap water, going to be using ice soon.
Edit, some 5.1ghz stuff.
CPU: Core2Quad q6600 G0 3.5GHz@1.4v (highest so far 4.2GHz)
GPU: XFX 9800GTX @ 850/1230
Ram: Samsung 4GB (4x1GB) 700MHz PC5300
Mobo: EVGA-NF68-A1 680i (P32)
PSU: Enermax Galaxy 850Watt DxX
HDD:WD5001AALS, ST3250410AS, ST3500410AS, ST3500320AS - 1.75TB
DVD: LG H26N,LG GH20LS10 both sata
LCD: Samsung 32" LN32A450, Samsung 226BW 22" wide
Sound: Logtiech Z 5500/Razor Barracuda HP-1 / AC-1
CPU & GPU: 3x Swiftech MCR320, 2x MCP655, MCW60 R2, Dtek Fuzion V2, 18 high speed yates @ 5v
3Dmark06:17,814 AquaMark:190,865
got to 5.2ghz @ 1.4vcore with the bucket of ice water, i tried for 5.3ghz but it wouldn't get into windows all the way. i went up to 1.5v and stopped there, didn't want to push my luck.
Could someone try this benchmark for me: http://1drv.ms/1zyMcOO
Extract the files (WinRar >5.x or 7Zip 9.) and execute NACA0012.bat.
Post a screenshot which shows the benchmark result and the necessary hardware information (amount of cores, core clock, NB/L3 > "uncore" clock and the memory clock).
If possible run it with turbo disabled and with and without HT.
It runs on Ivy Bridge and Haswell setups and supports up to 64 cores / threads.
Cant run it ...
ROG Power PCs - Intel and AMD
Thats a Pentium, it does not support the required instructions sets.
ah ...avx here or aes?
Congrats to all for those awesome results !!!
Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
ASRock X299 OC Formula
ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
1x Intel Optane SSD 905P 480GB
4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
SilverStone ST1500W-TI TITANIUM
Alphacool Custom Water Cooling
Those and few others.
Try this instead: http://1drv.ms/W2w9t9
Thats a generic version.
the same issue :-/ (Windows 7 SP1)
This works, tried myself: http://1drv.ms/1qA1tJ2
The software does not change the path based on the supported instructions so the AMD (FMA4, XOP, etc). instructions made it crash on Intel.
NACA0012_Haswell.bat - For Haswell (might work on Ivy too)
NACA0012_NFAA.bat - For CPUs without AVX, AES, FMA, BMI, etc (SSE4.2 is the minimum requirement).
NACA0012_AMD.bat - For 15h Gen. 2 & 3 CPUs.
AMD gets murdered in this test.
Steamroller is 20% faster than Piledriver and Haswell is 105% faster than Kaveri...
Dropping the AVX gives you around 10% performance penalty, however on Orochi it is actually quicker as AVX is broken in that one
OK, now I will be few hours away, so after Il be back home ...
I try to stablize my overclock... because I have some pc crashes.
I found the problem and the problem is Cashe multi
this is the best oc I found for my system with low voltage and low temps for 24/7
i5 4690K BATCH: L329C243
CPU Vcore: 1.166v
Cashe Voltage: Auto
CPU Ratio: 46 x 4 cores
Cashe Multi: 43
cashe at ratio 44 works very nice but past 10 ~ 15 minuts with intel burn test.. the pc crashes..
but cashe ratio 43 and cpu cores ratio 46 x 100 the PC works 100% stable with intel burn test and LinX ;D
CB at 5.1ghz w/1.469v, delidded ambient/water...same crappy mem.
windows screenshot
Any of you guys in Virginia near the fairfax MicroCenter ??? Was wondering were they selling 2014 chips and /or maybe if Neweeg was shipping 2014 chips. May have to take a ride !
I will buy a 4790k on amazon, she is sending chip L3 or L4 batchs?
