Page 2 of 6 FirstFirst 12345 ... LastLast
Results 26 to 50 of 136
Thread: 4790K & 4690K "Devil's Canyon" Overclocking Thread
  1. #26
    Brotherhood
    Apr 2005
    Land Of KADISOKA
    Devil canyon only better on on air cooling or water cooling. but for ln2 result nothing different with Haswell, still very hard looking good chip for ln2 result
    @dpa : seem like good cpu waiting ln2 result mate
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  2. #27
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Retail
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
  3. #28
    May 2007
    Hampshire, UK
    Quote Originally Posted by owikh84 View Post
    No need to up VDIMM at all? That's an awesome IMC.
    No need for extra SAV voltage its at stock & boots 3000 at stock which I think is quite good. Reckon performance may benefit from some volts with super tight timings & speed but not going to bother pushing this one.
    Quote Originally Posted by FUGGER View Post
    C-N... set the memory back to 2666Mhz and set tWR to 5 then rerun AIDA64
    Do you want this for some comparison?
    I already know these sticks can do 2933 tWR 5 its just the timings I ran above are my 24/7 settings so not optimized.
    No prob to put a screen up in a couple hours if you want it for comparison.
    Edit: Screen for the boss
    Home / Play Rig Asrock Z87 OC Formula/AC, i7 4770K L310B487, 8GB Corsair Dominator Platinum 2666 CL10, BeQuiet Dark Power Pro P8 1200W PSU, 120GB Corsair Force GT SSD, 2 x 1TB WD Sata Drives Mirrored, Palit 680GTX JetStream, Antec Kuhler 920, Windows 10 Pro, Logitech LX700 Deskset, AOC 27" Monitor.
    Work 24/7 Rig Gigabyte GA-Z97X-SOC Force, i7 4790K L418C133 ,8GB Team Xtreem LV 2600, PC Power & Cooling 850WPSU, 120GB OCZ Vertex 3 SSD, 2 x 500GB Hitachi Sata Drives Mirrored, Antec Kuhler 620, Windows 10 Pro 64 Bit, Logitech LX700 Deskset, Benq 27" Monitor.
    Home NAS DFI P35 T2RL Motherboard, Intel E6850 CPU, 8GB Nanya DDR2 6400, 2X 2TB Toshiba DT01ACA200 SATA Drives, ZFS RAID Mirror On Intel ICH9 AHCI, Artic Blue 850W PSU, Marvell Yukon 88E8053 Gigabit Ethernet, FreeNAS 9.2.1.5 RC, 64-Bit On 4GB USB2 SanDisk Cruizer Blade Thumb Drive.
  4. #29
    Jun 2002
    Las Vegas
    c-n your bandwidth is off, read and copy are way too low.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
  5. #30
    May 2007
    Hampshire, UK
    What do you make?
    I have seen this sort of problem before firstly comparing different versions of AIDA then only using 2 cores..... even opening CPU-Z before running AIDA makes a difference.
    Bandwidth looks ok against HiCookie http://img4.imagetitan.com/img.php?image=8_557.jpg
  6. #31
    May 2007
    Romania
    it's because his aida is 3.00,need to run with same aida version to compare results
  7. #32
    2.4C killer
    May 2003
    San Diego, CA
    Looking good guys, my 4790K should be ready for me after work tomorrow.
  8. #33
    May 2007
    Hampshire, UK
    L418C133 Slightly better than my L148C134
    Stock box cooler!! Cache did not want to run 1:1 @ 48 i.e. hanging 32M even with 1.4v
    Will give it a spin @ 5G On the 87 OCF tonight
    45 45 4/8 Stock Cache
    4.8 45 4/8 1.2 Cache
  9. #34
    Xtreme Enthusiast Gunslinger's Avatar
    Jan 2007
    Decatur, AL
    L352C119
    Boots and benchable at 4.7GHz on 1.2V - Geekbench and both Cinebench's
    Isn't responding to voltage very well though.
    Idle temps ~30C on Megahalems with a Delta, load 65 at 1.2
    Quote Originally Posted by chuchnit View Post
    Why do you always have to bring two sockets into everything?
    Quote Originally Posted by Movieman View Post
    Because a one socket system is only 1/2 a system..
    You got two balls don't you?
    I rest my case!
    http://www.usdebtclock.org/
  10. #35
    PI in the face
    Nov 2008
    where did you get it gunner?
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  11. #36
    May 2008
    Decatur, GA
    Finally got something to show, this is the L418C169 chip. 4.7GHz is doable though my H100i doesn't seem to do a good job keeping it cool.
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  12. #37
    2.4C killer
    May 2003
    San Diego, CA
    My chip arrived today. L418C164
    Prime and XTU stable so far 4.8ghz 1.348v, uncore 4ghz
    Did some benching 5ghz 1.4v
    Core temps are a problem though, seeing 23 degree variance in Realtemp. I'm using a custom Swiftech WC system.
  13. #38
    Jun 2009
    Yeah its because bios mobo sets certain adv 2nd timings too loose, I see the same thing by me @ 2133mhz CL9 vs 2666mhz CL11, 2400mhz CL10 is now ok since bios v1708
    Ie proper bandwidth @ 2400mhz, cache 4.2ghz @ 1.135v
    cache 4.4ghz test, gained 1points by multi, lost 1point by single..
    [Imgur](http://i.imgur.com/PcJ5wZU.png)
    4.2ghz cache looks the best balance., so far still very pleased with my 1yr old 4770K, I only wished it had 4790k thermals.
    Hopefully I can change this with better cooler ie 280L, 6-7C lower temps would look nicer
    intel i7 4770K @ 4.7Ghz (1.275V) - H90 pp fans | Asus Z87-Deluxe (bios v2004)| Crucial Balistix Elite @ 2400MHz CL10 1T 4x4Gb (1.65v) | ZOTAC GTX780 OC custom Amp!fan @ 1215mhz| X-FI Titanium HD @ Altec MX5021 | Chieftec NiTRO88+ 650W [52A] | Windows 8.1 Pro x64 WMC
  14. #39
    May 2007
    Hampshire, UK
    Not that bothered about my bandwidth it looks ok to me against others me so im happy. If Charles thinks its low show me what it should be & Ill tune for it but in all fairness what I showed is on a stripped 32m xp os & bandwidth is a couple k better with a 24/7 os. I don't see anyone doing much better so I'm happy.
    New chip doing better...
  15. #40
    Jan 2003
    Norway
    First tests with L3360107 4790K on Asrock Z97M OC Formula, Corsair H100.
  16. #41
    Mar 2004
    Fullerton, California
    Everyone is playing with the big boy chips, nothing about the little G3258
    Pre-ordered mine almost two weeks ago from Newegg. Originally 6/25, then they pushed it back to 7/1, sigh.
  17. #42
    2.4C killer
    May 2003
    San Diego, CA
    Let us know how that goes when you get it
  18. #43
    Jan 2003
    Sweden
    L418C133 looks like a nice batch many on sweclockers got that ones and all looks like doing around 4.9ghz without trouble.
  19. #44
    2.4C killer
    May 2003
    San Diego, CA
    And Lastviking comes in with the old school BH5 sig, love it
    I've settled for 4.8ghz 1.35v, 4.4ghz uncore 1.2v, RAM 2600 11-13-13-32 1T for my 24/7 stable clocks.
  20. #45
    XIP
    Nov 2004
    NYC
    L352C118 @ 1.31V h2o, better than most of my 4770Ks
  21. #46
    Aug 2008
    Atlanta
    Quote Originally Posted by Dumo View Post
    Stronger than my L329Cxxx batch which BSOD at 49x with ~1.3v (48x is benchable though).
    I'm kind of curious... How much Cache voltage to bench with uncore/NB at 48x?
    Ryzen 9 on the test bench... Sometimes older generation/tech as well.
  22. #47
    Xtreme Memory Hoarder
    Mar 2010
    L418C169
    Default VID on the Z87 OC Formula is 1.208v
    no waza so it will need a bit more voltage with waza, but definitely promising, now it just has to scale with cold.
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
  23. #48
    May 2008
    Decatur, GA
    Quote Originally Posted by l0ud_sil3nc3 View Post
    L418C169
    Same Batch # L418C169, not quite as strong.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  24. #49
    May 2008
    Decatur, GA
    Different batch on a different board, L331C501 on Asrock Z87 OC Formula. This one looks promising.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  25. #50
    Oct 2013
    Nice chip, are you able to pass wprime 32M @5G with this voltage?
