Results 1 to 13 of 13
Thread: Overclocking the FX8350 questions
    Jun 2014
    South Carolina
    Hi Guys,
    I've been overclocking for many years now. I havn't done a major upgrade for about 4 years so I'm kinda out of the loop.
    This Asus BIOS is impressive but I'm a little lost. So far I've just done a basic OC with a multiplier and voltage bump. I also hacked a H50 and H100 loop to be able to keep things cool at 4.8Ghz and 1.4375v. I made it up to 5.1Ghz at 1.5v but the temps started getting out of control.
    Now I've ordered a water cooling setup (will be here Monday).
    Apogee Drive II
    Mini res
    120mmx240mmx60mm all copper radiator
    4 120mm pure wing fans.
    Can anyone who is getting 5Ghz+ from their 8350 post their Sabertooth BIOS settings so i have a jumping off point?
    Thanks.
    John
    Apr 2003
    West Palm Beach, FL
    I think it will be more possible with your Water Unit, I just picked one up as well for cheap at Tiger Direct a few weeks ago. I just got my Hyper 212 EVO installed on it with a Silverstone FHP-141. I will have results soon on this chip, I am not getting anywhere near 5GHz but for the price, I simply do not think you can match it with anything else on the market.
    Update 1: Now Priming Stable at 4.5Ghz on 1.42v core.
    Update 2: Now Priming Stable @ 4.6 on 1.5v core.
    AMD Powerhouser!
    Tower: CoolerMaster Elite 371 | PSU: ThermalTake Smart M 850W
    CPU: AMD FX-8350 @ 4.6GHz on 1.4V's | GFX: HSI IceQ X2 R9 280X 3GB @ 1250MHz/1630MHz
    MOBO: M5A99FX PRO R2.0 | Mem: 8GB Corsair Vengeance DDR3 1600 (9-9-9-24-1T)
    HDD: Primary'd: Seagate 600 Pro 240GB SSD-Slave'd: Hitachi 1TB | Media Drive: ASUS DVD-Burner
    Cooling: Tower - 1990's Old School Lasko Box Fan|CPU - CoolerMaster Hyper 212 EVO with (2x) Silverstone FHP-141Push and Pull|GFX - Stock|NB - Stock|SB - Stock|Mem - Stock
    Temps(in Idle/Load Key) No OC: CPU - 28c/48c|NB - 22c/24c|GPU - 28c/45c| OC'd: CPU - 30c/56c|NB - 22c/24c|GPU - 29c/54c
    http://www.3dmark.com/fs/2325886
    May 2013
    Quote Originally Posted by Thick8 View Post
    Hi Guys,
    Apogee Drive II
    Mini res
    Thanks.
    John
    Wow if you've got an 8350 that'll do 5.1 on 1.5v then count yourself lucky. What are you using for stability test?
    HTPC : Ryzen, NH D-15, ASUS Crosshir VI Hero
    , 2x8 Team 3000, Asus GTX 980 Strix, Win10 Pro
    http://hwbot.org/user/johan45
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    The key with FX chips overclocked is keeping the vrms cool. Make sure a fan is blowing on them. ..memory fan coolers work best because they clip on.
    Good luck
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
    Apr 2003
    West Palm Beach, FL
    It looks like I am about tapped out at 4.6 on Air as well. The addition of another Silverstone 141 to the HS as a Pull Fan got me to 4.6
    Edit: Is 56c Load after 8hrs of Prime a decent Temp for this? Also, would Liquid Metal TP take me down in some temps if I got it?
    AMD Powerhouser!
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    56c seems about right
    ive always wanted to delid my FX chip like in the old chips, but i think they weld them on now?
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    Win7 Home 64bit
    My Rig
    Aug 2009
    Quote Originally Posted by tbone8ty View Post
    Be thankful AMD is using solder. If we had to delid our chips like some Intel users have been I think our members on the AMD overclocking side would be substantially scarcer. Now Intel says they are using TIM because it is cheaper than the solder they used to use... I'm not sure if the price different for Intel would actually reflect in an end user's price or is only a figure on some accountant's spreadsheet. I just know AMD needs all the help it can get keeping hobby overclockers buying their chips.
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    I did lap my heatsink. definitly helped have a solid surface area contact.
    Ill look at my bois tonight and give you some suggestions its been awhile though....play with the cpu-nb volts a little
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    Win7 Home 64bit
    My Rig
    May 2013
    Quote Originally Posted by Sidebinder View Post
    Temps are good, 4.6 is probably about as high as you're going to go on air.
    Jun 2014
    South Carolina
    Oops, I forgot I started this thread.
    So I ended up at 5.014Ghz stable at 1.488v. I set the FSB to 238 but it's running at 238.8. temps stays under 60c running Prime95 on all 8 core. The Asus BIOS has tons of options to stablize voltages and condition the current to make for a killer overclock. Needless to say I'm happy with the results.
    FX8350 @ 5Ghz (239x21) 1.49v
    Sabertooth 990FX rev.2
    2 XFX R9 290 DD @ 1100/1350
    8Gb Corsair DDR1600 9-9-9-24-41
    Swiftech Apogee Drive II
    Alphacool NexXxos UT60 full copper radiator
    Swiftech Micro res v2
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    show some results here
    ROG Power PCs - Intel and AMD
    Jun 2014
    South Carolina
    Here's a couple of screens of the BIOS settings and a Cinebench run. I'll do a Prime run this evening. I thought i was running 1.488 volts on the CPU but forgot that I raised it to 1.49375
ID:	131982   Click image for larger version.
ID:	131983   Click image for larger version.
ID:	131984   Click image for larger version.
ID:	131985   Click image for larger version.
    May 2008
    Czech republic
    nice
