Need a vdimm Mod for Shuttle SN45G XPC !
hello, i didnt know which fourm this would fit in, so i just thought id try this one.
i need a vdimm mod for my shuttle sn45g (nf2 ultra400 mainboard inside)
it only has 2.7v and thats not enough to get my memory at any decent timmings over 200fsb.
Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
DFI SLI-DR Expert 11-25 Bios
G-Skill 1gb GH UTT @210 2-2-2-5
BFG 7800GT OC 485/1170 NV 5rev3
74gb Raptor 300gb Maxtor 500gb Hitachi
OCZ 520w SLI 3.46v 5.16v 12.64v
Thermaltake CL-P0114 Big Typhoon
3dmark01 3dmark05
Heatware
Moved to Motherboard Vmods.. close enough.
Ive never heard of anybody modding one of these before, but it should be pretty simple (I hope)
As usual I need pics of the motheboard and or the names of the Vregs. Pics of both sides of the board may help as these systems tend to put mosfets and Vregs on the back sometimes to save space.
no matter what i cant get my camera to focus good enough in micro mode..
ive found the vcore chip, and the temp controll chip..
i think i know which is the vdimm ic but i wouldnt know what size VR to use..
i have a bunch and a mmeter, so im hopeing i can do it on my own w/o killing anything :\
3dmark01 3dmark05
Heatware
haha i was just about to post about a vmod for the SB75.... ill have to take some pics later
That HIP6301 on the right side of the picture is for Vcore....or for atleast every instance where I have seen it used that is. It is on many Abit boards...and is also on atleast one of the newer A64 boards.
If ya mod pin 7 with a 50K pot, you are good to go on that one. I cant make anything else out of that picture. If you reach a bottle neck with the Vcore mod, that means the ICs OVP is kicking in, and you then need to mod pin 10 with a 50k pot and lower the resistance on it a bit, then try the VR from pin 7 again. If you still cant get any further, keep lowering the VR from pin 10 a bit each time until you start to see movement on your vcore without the rig rebooting.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
- You may not post replies
- You may not edit your posts
Forum Rules
