thin radiator?
been out of WC for a while, just like to know which thin under <50mm radiator for LPM fan, yate loon 1200-1600rpm is the best? 240mm
Alphacool ST30 or HWLabs Nemesis GTS.
Originally Posted by
lowfat
HWLabs Nemesis GTS.
Just did a very confined build with a HWLabs Nemesis GTS X Flow (unique application) and really really love the quality and finish on the Nemesis series.
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
XSPC EX240 Slim Line Dual fan radiator (275mm x 121 x 35.5)
MagiCool SLIM DUAL 240 Radiator (273x121x30mm)
Black Ice Nemesis GTS (278mm x 133mm x 29.6mm)
Alphacool ST30 (278 x 125 x 30 mm)
The XFlow is 293mm but should offer some extra flow. I am curious about them though.
PC: Case: Zalman Z-Machine GT-1000 Black Brushed Alu -
Screen: HP W2408H -
Mobo: DFI Lanparty DK P45-T2RS PLUS -
CPU: Intel C2Q Q9550 -
Ram: Corsair Dominator 8GB PC2-8500 -
GPU: MSI 460GTX OC 'Cyclone' -
Sound: Asus Xonar D2X + Onkyo HT-S5105 5.1 set
Cooling Thermolab Baram + 2x tacens Ventus ice -
Storage: OCZ Vertex 60GB, WD Caviar Black 1TB, WD Green 3TB -
PSU: Corsair HX520 -
Peripherals: Duck Orion TKL (MX Clears) + Roccat Kova mouse
thanks ill take a look at those.
Crunching For The Points!
lowfat
Alphacool ST30
its all about the alphacool
- You may not post replies
- You may not edit your posts
Forum Rules
