    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 24 of 24
Thread: Haswell fighter arrived - Ivy Bridge Costa Rica does 4Ghz at only 1.048 volts........
    Xtreme 3DTeam Member
    Aug 2006
    Where You don't get nothin' for $
    Cool Haswell fighter arrived - Ivy Bridge Costa Rica does 4Ghz at only 0.984 volts........
    Hi folks,
    God of overclockers was with me when I was purchasing this stuff:
    8GB G.Skill TridentX RAM at 1.66 Vdimm. All out of the box, done on a 60EUR board..............
    More to come soon.
    EDIT: See post 12
    Last edited by camouflage; 07-14-2014 at 08:06 AM. Reason: New chip -----------> see post 12
    If nothing works nomore......:
    Aug 2006
    Here we go - 4.5Ghz at 1.232 volts:
    All on air.............
    Jun 2007
    nothing so special. did you tried @4.8 or 5.0Ghz yet? love to see chip response vs vcore at full load @ 5.0Ghz.
    [FSB<>BCLK]
    3930k@4.3Ghz 1.30v/4.5Ghz 1.35v full load 24/7 Lapped~gtx 1070Ti
    R4G Modded Bios 4901~Corsair 110GT+Ven-Pro 2.4Ghz 2x8Gb@2.4Ghz 1.65v C11~850Evo+970Evo 500gb~Win8.1X64~AX1200i
    SORRY FOR MY BAD ENGLISH
    Aug 2006
    Not really special, but low voltage. Here's 4.7Ghz at 1.336 volts:
    Need more cold for higher clocks.
    Apr 2006
    Bulgaria
    Sorry to disappoint you, but really good IB does 5GHz 32M with 1.3V or lower.
    X6 1090T (1010MPMW) @ 4267MHz 1.44V NB@3229MHz 1.33V | Asus Crosshair IV Formula | 2x2GB Corsair Dominator GTX2 @ 1845MHz 6-6-5-17-22 1T | Asus HD4890 @ 1050/4800 | Corsair HX850W | HAF 932
    EK Supreme HF | EK-FC4890LT | MCP655 + Koolance D5 Top | ThermoChill PA120.3 + 3x Enermax Magma | XSPC Bay res | Masterkleer 1/2" UV Red
    May 2009
    IND
    nice share
    Xtreme Enthusiast Gunslinger's Avatar
    Jan 2007
    Decatur, AL
    Quote Originally Posted by I.nfraR.ed View Post
    Golden chips do it with 1.2V or less.
    Quote Originally Posted by chuchnit View Post
    Why do you always have to bring two sockets into everything?
    Quote Originally Posted by Movieman View Post
    Because a one socket system is only 1/2 a system..
    You got two balls don't you?
    I rest my case!
    http://www.usdebtclock.org/
    Apr 2006
    Bulgaria
    Quote Originally Posted by Gunslinger View Post
    Yep. Mine does it with 1.26V and it's not golden
    Aug 2006
    So this is only avarage chip here.
    Changed board to AsRock Z77 Extreme4 and cooling to Corsair H60.
    RAM needs 1.68 volts on this board for 1300MHz at stock timings.
    Multi 49 ia a NOGO. Maybe some finetuning on the BCKL possible.
    Aug 2006
    Here's VID & Vcore @ stock speed - no winner chip but on the other hand not a bad one.............:
    Here're the temps, using CORSAIR H60 Liquidcooler - chip is not delidded, crappy INTEL TC onboard
    Vcore 1.36 volts - roomtemp 19?C.
    ----------> regarded to Z77.............
    Aug 2006
    Some undervoltig action - IMC doing 1200MHz even at very low voltage level:
    Aug 2006
    OK - new actor in da house.
    Again Costa Rica.
    VID @ 3.4Ghz 1.070v.
    L@@ks like 0.984 vCore @ 4GHz:
    Promising chip - delidded with liquid metal on die. Maby 5GHz? Time will tell.............................
    Aug 2006
    4.5GHz @ 1.144v:
    Aug 2006
    4.8GHz @ 1.280v:
    AIDA write very close to 40k...............
    Aug 2006
    4.9GHz @ 1.336v:
    Will try some 32M later.
    No boot at 5GHz so far ..............
    Aug 2006
    Finally it is a 5Ghz chip - @ 1.400v:
    After another bump of voltage it works. Nice chip, all results with DDR3-2600 and Corsair H60 cooler.
    Aug 2006
    It is possible to lower Vcore down to 1.392 @ 5Ghz:
    Temps during 32M never went above 50?C.............
  18. #18
    Jan 2008
    Athens -> Hellas
    With the H60 In a bucket of ice ?
  19. #19
    Aug 2006
    Quote Originally Posted by felix_w View Post
    Haha - no, chip is delidded, TC replaced by liquid metal. IHS on the die but not sealed again.
    H60 sandwich mounted, 2x 120mm fans.
    Using MX4 on the IHS, the H60 cooler is made of copper so it could get damaged by contact with liquid metal by the time.
    L@@king this way:
  20. #20
    Jan 2008
    Athens -> Hellas
    Really nice result!!!!
    BTW, i see what you did there, the led's of the G.Skill ram cooler are normally blue....
  21. #21
    Aug 2006
    No - I changed nothing. Maybe G.Skill changed the LED colour................
    The chip was a lucky punch - bought it for less bucks from a "gamer" on EBAY.
    Only information I had was the VID @ 3.6GHz - he ran the CPU on P67............
  22. #22
    Sep 2007
    I am running 4.5ghz 3570K at 1.22-1.23. I noticed too many blue screens while playing BF4. I cranked up the party to 1.25-1.26v according to CPU-Z readings. My Asus board overvolts slightly if CPU-Z is accurate. I didn't go with Haswell because it was new and the OC's I was seeing were not hitting 4.5ghz last year easily. 4.5ghz seems to be the sweet spot of the 3570K. I have been watching the devil canyon OC which is two generations newer and than ivy and the scaling is the same. Whenever I go above 4.5ghz, I take significantly more voltage. I have been rock solid at 1.264v with no blue screens. 1.23-1.24 has been running sell since Sept 2013.
    I always like to point out stable OC's vs. bootable and provable setups. I am only on 120mm Air cooling, not the exotic liquid cooling some of you have.
    i5-3570K 4.6Ghz Xigmatek Gaia Cooler
    Asus P8z77-V LK
    Toshiba 120GB SSD
    Samsung Spinpoint F3's 1TBx2 RAID 0
    Gskill Sniper 8GBx2 1866
    Sapphire HD 7950
  23. #23
    Aug 2006
    Quote Originally Posted by Hans Gruber View Post
    4.8GHz IVY is like ~4.6 HASWELL. But in the end yet I also decided to go with Z77 - 5GHz IVY was much easier to find and silicon lotto is an expensive hobby.......
    BTW - need a new mobo, AR Xtreme4 is limited at DDR3-2600. At that speed my 2400 G.Skills are running with stock volts - it's time now to squeze the sticks a bit.
  24. #24
    May 2009
    IND
    perhaps we got same batch
    ~NO DELID~
