+ Reply to Thread
Results 1 to 4 of 4
Thread: Best Video-Card OC-Tool?
    Dec 2003
    0
    Which tool is the best to oc a 9700?
    DD
    Chuck Norris Worshipper faruquehabib's Avatar
    Dec 2002
    Stevens Point, Wisconsin
    0
    powerstrip
    Xtreme Member MightyOne's Avatar
    Jan 2004
    Germany
    0
    I like the ATiTool http://atitool.ocfaq.com/ because it will raise the Frequencies little by little and keep scanning for artifacts - works pretty good w/ my Radeon 9500, the Core Clock of 398MHz is about the max. on stock cooling. But on the RAM it tells me 340MHz would still be free of artifacts, although the Infineon won't do more than 320 w/o a Vmod ...
    Need to get some Watercooling and take my soldering iron to wreak havoc on that card.
    Intel Core 2 Duo E6400
    ASUS P5B-E Plus
    4GB GSkill PC-8000 PQ
    Palit/Xpertvision 8800 GT
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    i like rivatuner. you can oc via hardware or driver. im only using the hardware oc tab though...
+ Reply to Thread
