I bumped on this :
A Japanese research team developed a technology to drastically improve the writing speed, power efficiency and cycling capability (product life) of a storage device based on NAND flash memory (SSD).
.... The new method forms a middleware layer called "LBA (logical block address) scrambler" between the file system (OS) and FTL. The LBA scrambler works in conjunction with the FTL and converts the logical addresses of data being written to reduce the effect of fragmentation.
...In a simulation, the research team confirmed that the new technology improves the writing speed of SSD by up to 300% and reduces power consumption by up to 60% and the number of write/erase cycles by up to 55%, increasing product life. Because, with the new method, it is not necessary to make any changes to NAND flash memory, and the method is completed within the middleware, it can be applied to existing SSDs as it is.
Source : Tech-On
Let's hope this will result in even better performing SSD's in the following years...
