Results 1 to 8 of 8
Thread: Blending Gases
    Xtreme Mentor
    Aug 2006
    Atlanta
    Blending Gases
    I hate starting these types of threads because it exposes my ignorance for all to see
    I received some advice on blending r14 with Argon to achieve better temps.
    The thing is r14 is very expensive so before I mix anything with r14 I want to understand how this will help.
    So I started playing with a mix of Argon and Ethelyn (Note this cascade has 3 stages and the second HX is adjusted for -85c at the moment).
    What im seeing is better temps with the Argon mixed in with a higher pressure to go along with it. The blend ratio is approx 15% Argon and the rest r1150.
    Now argon should not be able to liquify at this temp and pressure so im assuming its just the added pressure which is helping my temps go lower. Can anyone help me understand whats happening? Because im at a loss
    Never empower an idiot with a response....
    http://en.wikipedia.org/wiki/Troll_%28Internet%29
    Seller/Buyer Reputation:
    Heatware: http://www.heatware.com/eval.php?id=50905
    Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
    Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
    iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
    Jan 2005
    Germany
    When you have liquid R404A or every other liquid refrigerant the oil dissolves into the liquid refrigerant.
    The Argon should do the same in your liquid R1150 refrigerant. When you expand the mixture in your Evap the Argon should also evaporate and lower the temperature because of the lower boiling point.
    Xtreme Mentor
    Aug 2006
    Atlanta
    Thank you Patrick!!
    I was at a complete loss as to what was going on.
    -150c Club Member
    May 2005
    Northeast, USA
    Dissolving salt in ice makes the ice colder.
    Not exactly what's going on, but kinda what's going on.
    You are attempting to imbide the liquid r1150 with the argon, and therefore lower the average boiling point of the solution. The r1150 will absorb argon based on it's temperature, so more subcooling the better here.
    This is useful in systems when you achieve the load desired and have extra headroom to spend. As always, lower temps, less load. So you can spend the headroom in this manner. But it does mean you will gain quite a bit of pressure and heat on the compressor/condenser side.
    If you have a cooling question or concern feel free to contact me.
    Xtreme Mentor
    Aug 2006
    Atlanta
    Quote Originally Posted by n00b 0f l337 View Post
    Yep noticed that so im going to need to be very careful when blending with the r14.
    Thanks Adam, Patrick and MyTek
    Xtreme Mentor
    Mar 2006
    Redvers, Sask, Canada.
    It all so modified the vapour pressure of the host refrigerent, much like the hydrogen in an amonia absoprtion system, the pressure is static yet it boiled off as if it wher ein a lower pressure.
    Bring back natural selection! No more warning lables!
    The one and Only MG Pony
    Xtreme Enthusiast Gunslinger's Avatar
    Jan 2007
    Decatur, AL
    If anyone has any contact info with Scott other than PM here, please shoot him a message requesting that he come here to check his PM's. Thank you.
    Quote Originally Posted by chuchnit View Post
    Why do you always have to bring two sockets into everything?
    Quote Originally Posted by Movieman View Post
    Because a one socket system is only 1/2 a system..
    You got two balls don't you?
    I rest my case!
    http://www.usdebtclock.org/
    Xtreme Cruncher
    Oct 2008
    Chicago, IL
    Anyone remember the ideal gas law? PV=nRT. It's basic math to figure out what is going on.
