    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: TeamXtreem 2666CL11-13-13-35 2x8GB KIT are MFR ???
    Xtreme X.I.P.
    Jul 2007
    Montevideo - Uruguay
    Just wondering guys i had like 3 or 4 kits of this mem on MFR and the fastest i ever seen where the 2x4GB 2666CL11 that i took to validate at 3448 on the Asrock Z87, but i wonder those that are 2x8GB if they are MFR or CFR
    http://www.newegg.com/Product/Produc...82E16820313447
    Thanks !!!
    Sergio
    Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
    ASRock X299 OC Formula
    ADATA XPG SPECTRIX D60G (4x8GB) DDR4-3800C17 B-Die
    1x Intel Optane SSD 905P 480GB
    4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
    EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
    SilverStone ST1500W-TI TITANIUM
    Alphacool Custom Water Cooling
    3D Team Captain
    May 2007
    Munich, Germany
    CFR is a 2Gb IC, which means you can only build 2GB ( 8 chips ) or 4GB ( 16 chips ) modules. MFR is a 4Gb IC, therefore you can build 4GB or 8GB modules.
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Xtreme X.I.P.
    Jul 2007
    Quote Originally Posted by Don_Dan View Post
    hey my friend long time we dont talk !!! how are you bro !!! so you mean they can be MFR ???
    3D Team Captain
    May 2007
    Munich, Germany
    Yes, they're MFR.
    Will send you a message on FB soon.
    Xtreme X.I.P.
    Jul 2007
    Yes, they're MFR.
    Thanks brother !!!
    Jul 2004
    Saint Johns, FL
    I'm typing this on an Asus Rampage IV Formula X79/3930K rig currently running 4 of those modules. At the moment I've only tested them at 2400 since my IMC doesn't go much more. Going to be moving them over to a Haswell rig before too long for some additional testing. While some might be turned off by their appearance, I personally like the white spreaders, as they match much of the motherboard lettering, as well as the locking tabs on the PCI-E and Dimm slots and also the Corsair lettering on the H100.
    Those modules were $149 per 2x8GB kit just a couple of weeks ago and I got them with a 10% off discount code, so they were $135 per kit. They have increased to $162, however, for a 2x8GB 2666 CL11 kit this is still pretty cheap compared to the other options.
    In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
    http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
    Heat
    May 2008
    Decatur, GA
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Jul 2004
    Saint Johns, FL
    Quote Originally Posted by Shiranui Gen-An View Post
    That's kinda weird...I followed your link and it still shows $162.99 for me.
    Heat
    Moderator
    Oct 2007
    Oregon - USA
    162 for me as well
    Asus Rampage IV Extreme
    4930k @4.875
    G.Skill Trident X 2666 Cl10
    Gtx 780 SC
    1600w Lepa Gold
    Samsung 840 Pro 256GB
    May 2008
    Decatur, GA
    Hmm, maybe it went back up today.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Jul 2004
    Saint Johns, FL
    You must have caught them during one of those unadvertised "24-hour" sales.
    The version with the black spreaders is also listed for $163. Their white single-sided 2x4GB DDR3-2666 kit is priced at $99 making it one of the cheapest, if not the cheapest kit with those specs.
    Heat
    May 2008
    Decatur, GA
    The white kit is $159.99 now, and I had a 10% off coupon so I ordered two sets.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Jul 2004
    Saint Johns, FL
    At $144, for a 2x8GB kit of 2666 CL11, I just don't see how you can go wrong, especially when you compare that to the alternatives.
    Heat
    Xtreme X.I.P.
    Jul 2007
    Thanks bros yes are MFR they fly !!! So my GeIL 3000CL13
    will put pics soon
    Thanks to all !!!
    Sergio
    Jul 2004
    Saint Johns, FL
    And now, back down to $149.99 before the 10% off.
    Might want to consider contacting the Egg and see if you can't get them to credit you $10/kit. They are usually pretty good about that, especially if you are one of their good customers...and from what I've seen of your buying pattern, you certainly ought to qualify.
    Heat
    Xtreme X.I.P.
    Jul 2007
    Great kit guys here is at 2666CL11 1T Totally Stable 1.675 2x8GB Hynix MFR
    http://imgur.com/ypPa5HC
    And this ones are awesome !!!
    Nov 2005
    The Netherlands
    Why does a Team 2666C11 set need 1.675V for what is supposedly is its spec at 1.65 ?
  18. #18
    May 2008
    Decatur, GA
    1T can require more volts than 2T, right?
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  19. #19
    Xtreme X.I.P.
    Jul 2007
    Quote Originally Posted by TaPaKaH View Post
    thanks TaPaKaH the teamX work perfect at XMP 1.65VDimm
    but as im on a heavy 3x SLI 780HOF and M6E on 4770K 48HT OC when i go to 1T i need more volts...on the ASRock will do it without increasing VDimm and my CPU will be stable at 4.9HT at same VCore i'm on ASUS, but the ASRock Z87 OC formula gave me a bad suprise, the Tri SLI didnt work...I have my record on air on it at 3448 from 2666 on TeamX 2x4GB on ASRock.
  20. #20
    Xtreme X.I.P.
    Jul 2007
    Yeah bro long time we don't talk i told TaPaKaH but this don't happen on ASRock Z87 OC formula, The ASUS M6E is a great mobo but eat more volts on all
    Cheers !!!
    Sergio
  21. #21
    May 2008
    Decatur, GA
    Quote Originally Posted by andressergio View Post
    Oh wow, you didn't know the Asrock couldn't do tri SLI? No PLX chip like the M6E, though you found that out already the hard way
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  22. #22
    Xtreme X.I.P.
    Jul 2007
    I mean yes i didnt know bro, but i sold my M and bought the big one for some dollars more...so either way its a win but still no chip to bench i only have 1 4770K golden and 1 3770K Golden, but 4770K boots 5Ghz HT on the ASRock and can bench, on the ASUS boots but forget it eat volts like mad...4.9HT@ 1.2985 on the ASRock passes Cine R15...
  23. #23
    May 2008
    Decatur, GA
    New arrivals from NewEgg
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  24. #24
    Xtreme X.I.P.
    Jul 2007
    grats bro !!!
  25. #25
    May 2008
    Decatur, GA
    Playing with these on M6E. 2800 is braindead easy.
    Also managed 32M at 2933 on M7G:
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
