    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 19 of 19
Thread: Under the Ice for Hallowen
    Admin
    Mar 2003
    North Texas
    Red face Under the Ice for Hallowen
    Hallowen and I go back about 10 years ago from Team Puss forums. He asked me to do this single stage for him not because he doesn't know how, but he's just not set up to do it himself at the present time.
    This will be a simple walk-through of the procedure and parts I use to build my single stages. This unit will be built to handle 300watts of heat at approximately -35C using refrigerant r507. There will be lots of pictures. I hope no one minds.
    I use a 3/4 hp condenser to dissipate the heat.
    Along with that I use a matching 3/4 ton Danfoss 18CC compressor.
    Compressor is mounted to base and discharge and liquid lines are run first.
    I like to paint all copper joints to keep them from oxidizing and for general overall looks.
    While the paint is drying I work on the wiring.
    Simple ON/OFF switch
    Evaporator starts out smooth and clean on the inside but I like to rough it up a little to add more turbulence to refrigerant to aid in evaporating.
    Evaporator is then cleaned and brazed.
    Next up is assembly of line set.
    Finished brazing and clean.
    I like to pressure test line set to 250psi and dunk it in water to be sure I have no leaks.
    Cap tube is added and line set is wrapped with water proof mastic tape to hold the cap tube tightly to the suction line.
    Okay line set is all together and ready to be installed on compressor.
    More pictures coming after leak testing is finished. Thanks for looking.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    -150c Club Member
    May 2005
    Northeast, USA
    Great guide, nice and simple.
    As always I'm jealous of your apparent ease to find good condensers.
    If you have a cooling question or concern feel free to contact me.
    Administrator
    Nov 2007
    Stockton, CA
    Very nice Ron
    Almost makes we want another unit
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Beautiful work as always Ron , clean and tidy. The performance out this units is amazing , well worth it guys , this is a must have for any extreme overclocker. Congratulations to Halloween he will enjoy it very much.
    Mar 2005
    North West London
    Nice build, dunking in water is also my preferred way to check for leaks.
    Admin
    Mar 2003
    North Texas
    I started yesterday about 5:00 pm pulling a vacuum on the unit to get all moisture and contaminants out. I let it run all night until about 1:00pm today. During this time a did a triple evac. That should be plenty good to get a small unit like this cleaned.
    Add some r507 - and we have ice. Lots of ice.
    Next up is insulation, mesh on suction line and tweaking the charge to a 300watt heat load.
    UNDER THE ICE .com
    is the remedy
    Xtreme Mentor
    Aug 2006
    Atlanta
    Quote Originally Posted by n00b 0f l337 View Post
    Send me a PM im pretty sure we have the same source
    Never empower an idiot with a response....
    http://en.wikipedia.org/wiki/Troll_%28Internet%29
    Seller/Buyer Reputation:
    Heatware: http://www.heatware.com/eval.php?id=50905
    Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
    Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
    iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
    Admin
    Mar 2003
    North Texas
    Insulation and mesh finished and load testing is under way. So far I am pleased with this unit. At 300watts load we are holding right around -40C, evaporator temperature, in a 75F room temperature shop.
    UNDER THE ICE .com
    is the remedy
    Sep 2002
    Florida
    Looking Really Great, Can't wait to try it out on my Benching Rig!
    4930K@5.2GHz/ASUS RIV BE/G-Skill 16GB/4x EVGA GTX 780Ti Classified Kingpin Edition with EK-WB's/4x Rosewill Hercules 1600W PSU's for GPU's/Thermaltake 1200W for MB/Cooling: CPU-Vapo, MB/GPU: A/C Conversion Chiller
    Admin
    Mar 2003
    North Texas
    I hope you can find a spot for it.
    UNDER THE ICE .com
    is the remedy
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by runmc View Post
    Sep 2002
    Florida
    LOL!, It Definitely will require a little "Re-organization"!
    Sep 2002
    Florida
    OK Guys, I have re-arranged my Rig to make room for the New SS. The Pic shows the existing Asetek Vapochill XE (red outline at left top) that will be removed, and the area for the New SS (red outline at bottom).
    If I need more room than this, I can move the Rig support table more to the left.
    Sep 2002
    Florida
    I have just received word that Load Testing has been Completed by runmc and my 70LB Custom SS Phase Change will be Shipped Tomorrow and Hopefully be delivered this Friday so I can start the changeover from my good'ol Vapochill XE that has been used Cooling many of my previous Rigs over the Years!
    Administrator
    Nov 2007
    Stockton, CA
    Have fun man. I know you will like it !!!
    Admin
    Mar 2003
    North Texas
    Quote Originally Posted by Buckeye View Post
    BTW - your the best Bill!
    Here in North Texas the whether has gone from Winter to Spring about 5 times in the last week. About 3 days ago it was freezing which broke a record for coldest recorded day ever for that day. With temperature going up and down like that it makes it hard to tweak a charge. I need a steady 75F to get it the way I want it. Well anyway I finally got it finished and I am shipping in the morning. This is my load tester. I set it at 300Watts and charged for right around -36C evaporator temp.
    UNDER THE ICE .com
    is the remedy
    Sep 2002
    Florida
    Thanks runmc, I appreciate all the Hard Work it took to Complete this Project and I am eagerly awaiting the sound of the UPS Truck arriving so I can start to get this SS up and running some Benchmarks!
  18. #18
    Sep 2002
    Florida
    Finally Received the New SS Today and in the first two Pics you can see the Size Difference between My Old Asetek Vapochill XE and the "Monster" Single Stage followed by another Pic showing how Nicely the New SS Fits in the area I cleared next to my Benching Rig.
    I Still have to finish installing everything before any Testing/Benching can begin, But it is really looking good right now!
  19. #19
    Administrator
    Nov 2007
    Stockton, CA
    Yup, that machine Ron's makes is pure beast mode !
