Main Rig
Intel Core i7-2600K (SLB8W, E0 Stepping) @ 4.6Ghz (4.6x100), Corsair H80i AIO Cooler
MSI Z77A GD-65 Gaming (MS-7551), v25 BIOS
Kingston HyperX 16GB (2x8GB) PC3-19200 Kit (HX24C11BRK2/16-OC) @ 1.5v, 11-13-13-30 Timings (1:8 Ratio)
8GB MSI Radeon R9 390X (1080 Mhz Core, 6000 Mhz Memory)
NZXT H440 Case with NZXT Hue+ Installed
24" Dell U2412HM (1920x1200, e-IPS panel)
1 x 500GB Samsung 850 EVO (Boot & Install)
1 x 2Tb Hitachi 7K2000 in External Enclosure (Scratch Disk)
Entertainment Setup
Samsung Series 6 37" 1080p TV
Gigabyte GA-J1800N-D2H based media PC, Mini ITX Case, Blu-Ray Drive
Netgear ReadyNAS104 w/4x2TB Toshiba DTACA200's for 5.8TB Volume size
I refuse to participate in any debate with creationists because doing so would give them the "oxygen of respectability" that they want.
Creationists don't mind being beaten in an argument. What matters to them is that I give them recognition by bothering to argue with them in public.
I guess this is about as budget as you can get.
I just wish the reviewers would throw in a few older CPU's to compare against, old Athlon 64's/x2's, E4400's/E6400's etc - plenty of people using machines based on those just fine.
Main Rig
Entertainment Setup
What I saw, this performance is as some Athlon x2 4800+ or so. Not bad. Specially with more better encoding of video, because there is modern iGPU chip and of course less power . I can recomend AM1 socket as nice basic PC or HTPC
ROG Power PCs - Intel and AMD
I see quite a few basic business PC's based around new Athlons and Semprons!
I might build one miniPC for myself to take as diagnostic/recovery station when visiting my customers With a bit of tinkering I could even run it from external battery pack!
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55'' Samsung LED 3D TV
Just perfect for a basic mini itx HTPC, or whatever use you can come up with. What's quite interesting is an asrock mobo that can be powered from a 19v notebook charger/PSU. That's just amazing, you can ditch the PSU and, for example, mod something into where the ATX psu would've been. More hard drives? There's another mobo that's got 4 SATA ports, that's a little better... Can't wait to build one of these!
The possibilities are endless.
Scan already has boards and APU's for sale:
http://www.scan.co.uk/products/asus-...-hdmi-mini-itx
Less than ?60 for both? BARGAIN!
Main Rig
Entertainment Setup
any news in overclocking these units ?
I see today...Give me some time.
Anyone else find the benchmark results interesting when compared to the bulldozer arch? In a few cases you have 25w worth of jaguar cores offering 50% the performance of 95w A10s. Sometimes I think a higher clocked 8 core jaguar chip would have been a better option for AMD mid range, jaguar cores are very small in terms of die space as well aren't they?
Nice, I can change bclk at my board
check out how well the c2750 does in the multitheaded stuff as well, esp for a 20w TDP.
Anyone hear anything more about the console chips coming to retail since they first stated this like a year ago? If, how, socket, bga, etc?
Richland 6790K @ 4.713 Ghz / 2208 NB / 1123 gpu / 2304 Ram [96 Bclk]
F2A85-M Pro, Mushkin Black 2133, iGPU (8760D)
9.7L case (excluding 230mm fan) or 11.6L w/2nd rad fan
New Egg Bundle for the Yanks: $99
AMD Sempron 3850 Kabini 25W
ASRock AM1B-ITX AM1 SATA 6Gb/s USB 3.0 HDMI
Cooler Master Elite 130 - Mini-ITX Computer Case with Mesh Front Panel and Water Cooling Support
I'm in
It's going mano a mano against my A6-1450 Temash.
I'm still laughing at Anand for testing CB and POV-Ray with the i7 4770K in the benchies.
Best review around so far: http://nl.hardware.info/reviews/5330...sktopplatforms
Apple to Apple 5350 (25w) vs J1900 (pseudo 10W) = 5350 wins without doubt (by the way, it destroys the J1900 in idle consumption)
I have only 5150 , not topmodel
next review at Toms:
http://www.tomshardware.com/reviews/...ew,3801-8.html
Fold for XS!
You know you want to
The upside of socketed kabini, as has been told in many reviews, is the ability to upgrade. Considering AMD's history on that, apart from FM1 I think this little socket will go on for a few generations. Beema is supposed to be released soon, that should be a great upgrade to kabini and would also enable HSA for this platform... which in the future, if such software takes off, would make an interesting little chip even more so.
In my case, a 35-40 U$S mobo and some more for the 5350 is the perfect foundation for an htpc that would put that LCD TV to good use, and would easily double as an internet PC for the parents, or guests, occupying little to no space. Hell, you can even hide it! A reviewer noticed that for such tasks it is indistinguishable from higher powered platforms... If no gaming is intended, anything more powerful is overkill. It's quite appealing, especially if you live in a country that is economically backwards and sinking like the titanic, but worse. I'm also thinking of many old office PCs (old athlon XPs, P4s) that could be replaced with this... I'll certainly be making some recommendations in the future.
I can only applaud AMD for putting kabini in a socket and undercutting intel's atom crap in both price and performance. I think AMD should focus on their cat cores since they've proven themselves lately... Intel did something similar with the Pentium M after all.
Would definitely like to see how this stacks up against a Core 2 Duo and an Athlon 64 x2 for IPC...
Main Rig
Entertainment Setup
No DTX boards makes me sad. Amd really needs to bring this back.
If this had ECC support, this would make a very nice VM set up w/ ZFS for storage & a 1x video card for playback. I can only dream.
For non-power users, this is just awesome. Normally, I'm not excited about "slow" cpus, but this is a nice segment to get into. Rigs are cheap, especially if we can OC them.
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
Impressive indeed.
i7 920@4.34 | Rampage II GENE | 6GB OCZ Reaper 1866 | 8800GT (zzz) | Corsair AX750 | Xonar Essence ST w/ 3x LME49720 | HiFiMAN EF2 Amplifier | Shure SRH840 | EK Supreme HF | Thermochill PA 120.3 | MCP355 | XSPC Reservoir | 3/8" ID Tubing
Phenom 9950BE @ 3400/2000 (CPU/NB) | Gigabyte MA790GP-DS4H | HD4850 | 4GB Corsair DHX @850 | Corsair TX650W | T.R.U.E Push-Pull
E2160 @3.06 | ASUS P5K-Pro | BFG 8800GT | 4GB G.Skill @ 1040 | 600W Tt PP
A64 3000+ @2.87 | DFI-NF4 | 7800 GTX | Patriot 1GB DDR @610 | 550W FSP
you mean like 2 of these? http://www.techpowerup.com/198517/bi...herboards.html
Main Rig:
Processor & Motherboard:AMD Ryzen5 1400 ' Gigabyte B450M-DS3H
Random Access Memory Module:Adata XPG DDR4 3000 MHz 2x8GB
Graphic Card:XFX RX 580 4GB
Power Supply Unit:FSP AURUM 92+ Series PT-650M
Storage Unit:Crucial MX 500 240GB SATA III SSD
Processor Heatsink Fan:AMD Wraith Spire RGB
Chasis:Thermaltake Level 10GTS Black
