how to run a Kryos Pro on a bare processor?
I know EK makes a kit for bare die operation, but given the mounting nature of the Kryos (I'm using an EK integral socket backplate for it) shouldn't there be a way to shim it down? I'm not using the excessive bow O-ring. If anyone even just knows the IHS thickness of a 3570K I'll be fine. From what I can tell a shim on the springs or cutting the studs either one will work, I just don't know how much to add/remove.
- You may not post replies
- You may not edit your posts
Forum Rules
