Results 1 to 4 of 4
Thread: Macbook Pro 13.3
    Xtreme Mentor
    Nov 2006
    Florida
    Macbook Pro 13.3
    Anyone knows which i5 and i7 models Apple uses on their current 2014 Macbook Pro 13.3 Retina models?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    the dual core ones used in the serface for the i5 and the i7 dual core SOC for ultrabooks and tablets on the i7.
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Mentor
    Nov 2006
    Florida
    Do you have the specific model numbers? ex: Core i5 4xxx etc etc ?
    For the i5 I doubt it is the same as Surface since wikipedia states 3317U and its stock clock speed is 1.7Ghz while on the Apple store the lowest 13.3r has a 2.4Ghz.
    I just pretty much need two models which are the following:
    2.6GHz Dual-core Intel Core i5, Turbo Boost up to 3.1GHz
    2.8GHz Dual-core Intel Core i7, Turbo Boost up to 3.3GHz [Add $200.00]
    If anyone knows the specific model, I would really appreciate it.
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by slim142 View Post
    same chip does not mean same squ. apple would use the non U versions since they are not in tablets.
