Not yet, but trust me, this is planned
I'm trying to improve my efficiency on catzilla, then, let's go for cold
Single card, max on air for me. Stock bios, pushed the voltage and power sliders to the max via GPU Tweak
1225 boost on the core, memory at 8000MHz
1.21 Vgpu
1.65 Vmem
110% power limit
74.8% ASIC
max temp 54 degrees F
idle temp 31 degrees F
4960X
Asus GTX 780 Ti Matrix Platinum - stock air cooler
Rampage IV Black Edition
4x4GB Corsair Dominator Platinum
Corsair AX1200i
Single card, max on water using the stock bios, pushed the voltage and power sliders to the max via GPU Tweak
1250 boost on the core, memory at 8058 MHz
1.21 Vgpu
1.65 Vmem
110% power limit
74.8% ASIC
max temp 31 degrees F
idle temp 23 degrees F
4960X
Asus GTX 780 Ti Matrix Platinum - EK universal block
Corsair AX1200i
I have made a shoot with mine, very quick test, I killed operating system... -> session abort.
1700Mhz @1.4v for Catzilla 1440p
how cold were you running?
Only -80?c
CBB @-60?C on my VGA.
Will try it today.
Dumo, is it hard to solder connector for Matrix OC panel ?
crazy scores
can u guys try it with skyn3t bios.
Asus 780 ti matrix is simply amazing. The best card I've ever had. At nvidia locked voltages it just ran 1401mhz on the core and 2000mhz on the memory.
1.21v on the gpu
1.65 on the memory
68.5% Asic
Skyn3t bios
Max temp during 3dmark11 was 62
1400 on 1.21 is a gem card indeed.
lol, i bumped 3.3v and pll voltages a bit and 1450 almost passed with 1.21v, running with my core waterblock now. Amazing card. Will bump a bit more and sure it will pass.
UPDATE
The card is amazing, running nvidia voltages 1.21/1.65 still, measured with multimeter 1.225/1.672 I just ran 1462 on the core and 2005 on memory.
Max temp 44 still due to low voltage
Proof:
Thanks to ASUS Gpu Tweak, my killer card will never more run. After forced to enable ln2 mode to get more voltage range, I tried to apply safe settings in gpu tweak to test the other bios, after hitting apply with settings like 1200/2000 1.22v/1.65v my screen went crazy black with colours. I can't boot into windows properly with it anymore, screen just goes crazy when it is about to reach desktop.
WHy hasn't asus fixed this, matrix was announced many months ago and their own software killed my crazy card instantly. Why do they advertise it as an easy overclockable card when even their own software is faulty.
I'm really sad right now, there goes 700 euros. And the saddest thing about it is that even if ASUS gave me a new one, it will never be like this one that did 1462/2005 with so low volts.
Never try LN2 mode when on air stock/water
