Results 1 to 17 of 17
Thread: Hardware Labs introducing Nemesis GTX Series
    Xtreme Reviewer
    Apr 2011
    Black Ice NEMESIS GTX Advanced PC Radiators
    The Black Ice PC Radiators ushered the dawn of professional PC watercooling over 10 years ago with the Black Ice Pro and Xtreme series. These were followed by the groundbreaking Black Ice Gen Two, GTS and GTX PC radiators, providing unprecedented performance for compact form factor heat exchangers.
    Enter NEMESIS
    The Black Ice NEMESIS Advanced PC Radiators are a culmination of over a decade's worth of experience in ultra compact heat exchanger design. Black Ice NEMESIS radiators feature Supercruise optimizations that maximize performance for an even wider range of fan speeds. The Black Ice NEMESIS GTX radiators will achieve ultra-stealth operation using sub-800 rpm fans and scale up performance with higher rpm fans.
    Internal core optimizations provide an unprecedented 15% increase in internal surface area that also enhances overall system flow rates. A radically optimized 25 micron copper fin core provides increased frontal surface area, while also dramatically reducing air pressure drop enhancing fan performance.
    Bring It On!
    These optimizations combined with the unique Black Ice GTX dual core flow pattern yields a single 120mm radiator capable of handling 450W. The NEMESIS 120 GTX will essentially allow a system builder to unify a CPU/GPU loop into one 120mm radiator.
    The Black Ice 560 GTX, the monolithic quad-140mm fan iteration, is rated for 2500W of heat dissipation, easily providing top notch thermal management performance for any overclocked quad SLI/Crossfire rig, with surplus capacity to spare.
    Quality Beyond Skin Deep
    The trademark craftmanship of Black Ice radiators remain unsurpassed and the NEMESIS maintains that tradition. The new finish, dubbed Dark Matter emphasizes the aggressive angles on each NEMESIS radiator with an even more solid build quality. (Euro Version uses a Black Carbon finish)
    And it doesn't stop there. The quality of the Black Ice NEMESIS radiators do not just go skin deep -Hardware Labs backs each Black Ice NEMESIS radiator with a lifetime warranty* against defects. Another first in the industry.
    Black Ice NEMESIS GTX radiators are now being made available across Europe and is exclusively distributed by CaseKing GmbH.
    Hardware Labs Performance Systems, Inc., is the pioneer and only company specializing in the design and manufacture of high performance PC watercooling radiators. It serves numerous industries with its high performance compact form factor heat exchangers, from high performance computing, motorsports, military, medical, power generation and power electronics.
    Black Ice, GTX, NEMESIS, and Supercruise are trademarks and/or registered trademarks of Hardware Labs Performance Systems, in the US, EU, and other other countries. Other company and product names maybe trademarks of their respective owners.
    Technical details:
    Name: Hardware Labs Black Ice NEMESIS GTX Radiators
    Material: copper (core), brass
    Color: Black (special Dark Matter finish)
    Fans mounting points: one sided
    FPI (fins per inch): 16
    Fittings: standard 2x G1/4" (inlet/outlet)
    Manufacturer warranty: lifetime
    Features:
    Made from scratch with conflict-free materials
    Easy and fast installation
    Highest cooling efficiency radiators on the market
    Improved BlackIce technology - increased internal coolant flow rates, 15% more tubing area
    Stealth Technology - fins optimized for 800 rpm ultra silent fans
    SuperCruise Technology - core optimization for fan speed scalability
    RoHS Compliant
    TDP heat generated by high-end CPUs:
    Intel Core i7-4770K 3.5 GHz (Haswell) Sockel 1150 - 84W
    Intel Core i7-4960X 3.6 GHz (Ivy Bridge E) Sockel 2011 - 130W
    TDP heat generated by high-end graphics cards:
    AMD Radeon R9 290X - 290W
    AMD Radeon R9 290 - 275W
    NVIDIA GeForce GTX Titan Black - 250W
    Radiators cooling performance using silent 800 RPM fans:
    Hardware Labs - Black Ice - Nemesis GTX 120 - Copper - 450W - 52.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 140 - Copper - 550W - 62.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 240 - Copper - 1000W - 82.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 280 - Copper - 1200W - 99.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 360 - Copper - 1800W - 109.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 420 - Copper - 2000W - 139.90 Euro (incl. VAT)
    Hardware Labs - Black Ice - Nemesis GTX 480 - Copper - 2200W - 149.90 Euro (incl. VAT)
    More info at:
    http://www.hardwarelabs.com/nemesis/
    Sep 2005
    Toronto, Canada
    Someone needs to test these ASAP. If their claims are true, which i highly doubt, it would be quite amazing... A single 120 capable of 450w dissipation, right.
    q9550 @ 444 x 8.5 1.3v - Venomous X
    p5q DLX
    Ocz RPR 1066 4 x 2g @ 1066
    eah5870 V2 @ 920/1250 - HR-03gt
    Antec Fusion Remote MAX
    Xonar HDAV1.3
    Ocz zx850w
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Quote Originally Posted by madmaxx View Post
    With a 3000rpm+ fan they probably can.
    Xtreme Member KiSUAN's Avatar
    Oct 2007
    Banana Republic
    Quote Originally Posted by lowfat View Post
    They say silent 800 RPM fans
    Jul 2004
    London
    More interested in the Nemesis GTS, would be a good competitor to the Alphacool ST30 and a bit less than 1mm thinner which is all I need for cramming it in the 250D.
    i7 920@4.34 | Rampage II GENE | 6GB OCZ Reaper 1866 | 8800GT (zzz) | Corsair AX750 | Xonar Essence ST w/ 3x LME49720 | HiFiMAN EF2 Amplifier | Shure SRH840 | EK Supreme HF | Thermochill PA 120.3 | MCP355 | XSPC Reservoir | 3/8" ID Tubing
    Phenom 9950BE @ 3400/2000 (CPU/NB) | Gigabyte MA790GP-DS4H | HD4850 | 4GB Corsair DHX @850 | Corsair TX650W | T.R.U.E Push-Pull
    E2160 @3.06 | ASUS P5K-Pro | BFG 8800GT | 4GB G.Skill @ 1040 | 600W Tt PP
    A64 3000+ @2.87 | DFI-NF4 | 7800 GTX | Patriot 1GB DDR @610 | 550W FSP
    Mar 2008
    川崎市
    It is likely that they just twisted some words around in the marketing department and what they meant is more along the lines of: You can use it to cool components with a combined rated TDP of 450W while keeping them at a temperature slightly lower than the stock cooler manages.
    I am Xtreme
    Oct 2005
    Quote Originally Posted by LightSpeed View Post
    About time they changed the GTS. They were terrible radiators before. They seem much more appealing to me now.
    May 2007
    'Zona
    Quote Originally Posted by KiSUAN View Post
    At 16FPI, that seems highly unlikely.
    Originally Posted by motown_steve
    Every genocide that was committed during the 20th century has been preceded by the disarmament of the target population. Once the government outlaws your guns your life becomes a luxury afforded to you by the state. You become a tool to benefit the state. Should you cease to benefit the state or even worse become an annoyance or even a hindrance to the state then your life becomes more trouble than it is worth.
    Once the government outlaws your guns your life is forfeit. You're already dead, it's just a question of when they are going to get around to you.
    Jan 2009
    Central PA/Southern NH
    Whats the radiator thickness on the 480? I am limited with what I can fit with the PSU in the bottom of a 900D.
    [Intel core i7 4820K..........Asus Rampage IV Black Edition] LAN Parties attended:
    [512GB Samsung 840 PRO 512GB......2xWD Black 7200 2TB RAID0] FITES [fites.net] 2012, 2011, 2010, 2009, 2008, 2007
    [32GB G.Skill DDR3 2400 4x8GB....2xEVGA GTX780ti Classified] L'Pane NorEaster [lpane.net] 2010, 2009, 2008
    [Corsair 900D.......Primochill CTR 250......Corsair AX1200i] Quakecon [quakecon.org] 2010, 2009
    [MCP35x2.........Swiftech Apogee HD......Swiftech MCR420-XP] PAX East [east.paxsite.com] 2012
    Apr 2005
    55.7mm. I'm wondering if CaseKing will deliver to the US, I need new radiators for a build.
    Sep 2005
    Quote Originally Posted by C3 View Post
    Any reviews out yet?
    Hi Everyone. Been ages.
    This should answer most questions.
    Black Ice Nemesis 360GTX review:
    http://youtu.be/90In6ErISm0
    And one for the Black Ice Nemesis 240GTS XFlow:
    http://youtu.be/VIlZo8W4B0Y
    Oct 2005
    they were not terrible. in fact i still have them in my loop. you just need to run them with high speed fans. it's basically a single layer GTX, but to make up for the lost layer, they increased the fin count, to compensate for the same amount of heat exchange rate. and to get all that air through, you need high speed fans. it's most ideal for people working with limited space. i have mine setup with fan profile that throttles from 800rpm to 2000rpm according to CPU load. but performance wise, it performs on par or even outperforms common popular dual layer rads. i learned all this from martin.
    EDIT:
    however, i do have to say that i have doubts that the new Nemesis GTS will be able to match the Nemesis GTX in high rpm. on paper alone, the fin counts are the same between GTS/GTX Nemesis. but i could be wrong. hopefully new reviews will start popping out. there're those of us working with limited space who are interested in the single layer Rad.
    i7 3770K @4.9ghz (1.42v Delided)
    Watercooled w/Black Ice GT Stealth 360(360mm) + GT Stealth 120 (120mm) radiators
    W/ Swiftech MCP655 vario (D5)
    Koolance CPU 380i waterblock
    AsRock Z77 Extreme6
    Gskill DDR3 1866 2X4GB 9-10-9-28
    Radeon HD7950 @1200Core/1600mem, Crucial M4 512
    Aug 2006
    That's funny they want that much $ for one of those, I can get way better/more for less...
    Custom case laser cut from a 3/16" thick sheet of brushed Aluminum 8"x80" & cold formed into a box then anodized black with 1/2" Poly-carbonate side panels..[.fully modular, all aluminum mounting brackets, HD bays, and mobo tray are removable...down to the bare box
    --Asus Maximus V Gene--
    --Intel 3770k @4.2 GHz De-lided and I soldered an Arctic Twin Turbo to the Intel.
    --MSI R7970 3GB @1150, 1500 cooled with an Arctic Accelero Xtreme--
    --G.SKILL Ripjaws @2400 MHz --
    --SeaSonic X-1050 Gold--
    --128 GB Sandisk UltraPlus is was only $59 new! Seagate 1TB HD--
    --Samsung S23A750D 120Hz monitor--
    --Razer Tarantula-- keyboard, yes it is like 8 years old!
    --Corsair M60 mouse--
    --Klipsh Promedia 2.1-- I rock stereo speakers the way they were meant to be rocked
    -- 100% Fun ...
    Does it ever shock anyone else when your hear someone use Darwin's "survival of the fittest" to justify genocide?
    Oct 2005
    has anyone tried the Nemesis GTX and GTS?
    I am really interested to know how the two stack up against each other.
    AsRock Z77 Extreme6
    I am Xtreme
    Oct 2005
    Quote Originally Posted by howzz1854 View Post
    EDIT:
    This day and age people want quiet systems. High FPI just ain't cool anymore.
    Quote Originally Posted by DefStar View Post
    HWLabs is as good as you can get for radiator build quality. So can't really get better radiators than this.
    Oct 2005
    that's a good point, however, the higher FPI GTS has shown to out perform many dual layer Rads in the same size class. so it is "cool" for those who want to squeeze out a few more degress of performance, after all, one of the main reason one go through all the trouble to convert a system from stock to water cooling. and secondly, PWM takes care of all the issues with noise. my system is setup to throttle from 1000rpm to 2000rpm, just as any stock HSF setup.
    high FPI isn't for everyone, but for many who work with limited space, there really isn't any other solution other than a thinner rad, higher FPI, and PWM fan.
    AsRock Z77 Extreme6
