I put an 280x next to my 7970 lightning they are all stock. Have a 3770k @ 4.25 16gb ram etc etc.
Today i don't know why but i see that bf4 started to perform bad even sometimes under 60. When i check with gpuz and afterburner i saw that gpu1 (7970) runs around %50 but gpu2 always %99. Can this cause this or this is a problem that i should fix? I disabled ulps or something like that but that doesn't solved this. also should i make them run at same clock speed manually?
i can score 6002 on fire strike extreme with this setup which is not optimized for benchmarking actually it isn't optimized for anything
